Question about Compaq Computers & Internet
My Compaq 615 laptop when start the lights come on and runs but black screen? Please help
I switch the laptop on all the lights come on and it runs but screen black..
Posted by Debbie Els on
Dayton Computer
  • Compaq Master
  • 1,578 Answers
Lights can come on but your CPU is not booting the Operating System. Can be the Hard drive or windows os.
Posted on Dec 25, 2018
5 Related Answers
Anonymous
  • 47 Answers
SOURCE: Please help me with my COMPAQ ARMADA 1700
Double check to make sure there is no floppy disk or CD-ROM disk inserted when you boot. If there is definitely no floppy or CD, your hard drive may have crashed or been corrupted. You can try installing Windows again, but it might not work if your hard drive is faulty. If it's faulty, you'll need to head to the local computer repair shop or have a geek friend help get and install a new one, then reinstall Windows.
Posted on Jun 11, 2008
Anonymous
  • 93 Answers
SOURCE: compaq laptop screen is black, fan isn't running but the power..
Check if any external monitor on or any noisy when you switch on the laptop? If not, the motherboard was faulty, which means the BIOS on the mother board was damaged.
Posted on Nov 20, 2008
Anonymous
  • 50 Answers
SOURCE: compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Posted on Apr 06, 2009
Gyanendra Kumar
  • 479 Answers
SOURCE: screen black computer laptop not starting
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
Posted on May 29, 2009
greg_margo
Greg Margossian
  • 1959 Answers
SOURCE: Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Posted on Dec 16, 2009
Compaq presario cq71 power indicator comes on for about 5 seconds then turns off without battery
cq71 check tips:
please clean memory stick pins and slots first if not ok, check next
1) plug in adapter to check jack led lights on or not, if no lights on no switch on.
2) if the jack lights on, then to switch on laptop, will be showing the more lights on, you are hearing cpu fan running. if nothing appear or every thing running with dark screen, or hard to switch it off go next
3) pull out the wireless card then switch on again, see what happened, if ok change a new card, if not ok, it is motherboard hardware issue
Dec 29, 2012 | Compaq Presario CQ60-220US PC Laptop
Please I'v been using a compaq 615 (windows 7) and
Please check the under of your laptop for any sticker label containing a "Product Key". If it is not there, check the documentation that came with your laptop.
Nov 14, 2012 | Computers & Internet
Hello everyone, I have a Compaq 615 laptop and since this mourning I have this problem: when I start the laptop - my computer starts, but on the screen nothing's happening! I know this because my Skype...
It appears your laptop is booting up but the screen is black. the problem most likely a back light problem. this could be caused by a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instruction to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 11, 2010 | Compaq Computers & Internet
Compaq presario 615 does not display when switched on.
Does the laptop appear to boot uo and the hard disk LED flash but the display is black. Then the problem could be a back light problem which could be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
Nov 05, 2010 | Compaq Computers & Internet
Compaq laptop screen is black, fan isn't running but the power light is on, do you think its the processor? or what
if i have to pay for it forget it...i thought it was foc as it states "solve your problem for FREE" and no i haven't solved the problem
Nov 19, 2008 | HP Compaq Presario 2200 Notebook
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Monitor blank
you might have to get a new screen cuz that happened to me a couple years ago but on a diff computer and i had to replace the whole thing through compaq
Apr 21, 2008 | HP Compaq Presario V2000 Notebook
Laptop wont power up.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Good Luck, Read and folow instructions/Please dont for get to Vote/Thank You.
Dec 25, 2007 | Compaq Presario R3000 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
