Question about Electrical Supplies
How to repair a Smart Electrician shop light model PES120LEDST1-5
Posted by Rod Mulder on
sherlywang
    Master:
  • Electrical S... Master
  • 425 Answers
25kva-3000kva diesel generator set website www.dieselgeneratortech.com
Posted on Nov 29, 2019
2012 focus interior lights not working
Which interior light's ? Dash panel , dome etc.... One's that can be dimmed or not ?
All the light's are controlled by the SJB - smart junction box ,ford's body control module . Your best bet , take it to a qualified repair shop.
Oct 21, 2018 | Cars & Trucks
2006 passion dash lights fuse blew 7.5amp number 6 replaced fuse with 10amp,all i had at time, now smell of burning and dash lights except clock are out again.
Hello
When a fuse blows up , means you have an electrical problem in that circuit, you need to check the wires that are connected to that fuse for short circuit
Jan 12, 2017 | Smart Cars & Trucks
Where is the 96 Lincoln Town car turn signal relay located
Doesn't have a turn signal flasher relay . Has a LCM - lighting control module ! (computer ) . Your best bet would be to take your vehicle to a qualified repair shop . 1995 1996 LINCOLN TOWN CAR LIGHTING CONTROL MODULE LCM0 results You may...
Aug 09, 2016 | Lincoln Cars & Trucks
My telefunken Vegas has a crack on the lcd model VPM-420FHDISerialnmr062010552 FHDI hw much will it cost me to repair it pls
you would be better off replacing the 42 inch TV rather than repairing it. Suggest you shop around for a new TV. Cost for a new 42 inch as a guess would be between 300 to 500 dollars. Good luck. Invest in a smart tv.
Nov 19, 2015 | Televison & Video
Why do all my instrument lights come on blinking while driving then the truck goes dead
Your have electronic problems , or wiring issues ! Your best bet is have a automotive repair shop check it for you . I don't know the year of your vehicle or the make an model but from the 80's on the amount of electronic controls has quadruped . The instrument light's can be controlled by a body control module or a smart junction box as ford calls it, but all makes have some form of electronics , the instrument cluster even has a microprocessor inside . If your not up on automotive electronic systems I very strongly suggest you take it to a repair facility !
Sep 26, 2015 | Cars & Trucks
My shop was closed for 6 weeks during Christmas and New Year period ie half of my business period did not have any electricity consumption. However, my electricty usage was the same as the previous...
you did not mention what sort of business you run
if it has commercial fridges or cool rooms , they still use power
if it was a book shop the power consumption would be about 90% less as all that would be running is the security lights and security systems
smart meters can be circumvented so get in a qualified electrician to check that power is not being stolen and then get in a lawyer
Aug 16, 2017 | Computers & Internet
Had both switches to ON, with the dial turned to 7 (highest). No lights on, unit is cool. verified outlet is OK, and tried several other outlets.
well obviosly he heater has electrical fault seek electrician, the lights not coming on means electrical fault on heater if new get replacement under warranty if not get electrician to fix for you do not attempt to fix electrical problem if your not a electrician or a restricted electrician, maybe an appliance fixing shop may be your best place to try but it sounds deffinatly electrical
Dec 09, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Electrical Supplies Logo
186 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
