Question about Dual Audio Players & Recorders
Why does my Dual XDM280BT play tuner and usb loud and clear but the volume is lower and fluctuates?
Posted by Shannon Colomb on
3 Related Answers
Anonymous
  • 432 Answers
SOURCE: audio fluctuating
First check all the cables. If you have a DVD player connected, play a movie and see if the volume is normal. We want to eliminate the possiblity of external problems. Write back and let me know, and we'll go from there.
Posted on Jun 30, 2007
SOURCE: Phono plays lower in volume than cd and tuner.
Hello. As per the post before me, if you have a receiver with a Phono input(many receivers don't have one anymore) the output of a phono cartridge is around 30 millivolts, vs 300 millivolts for a CD(10 times the amount) or any other line level device. A Phono preamp, also has RIAA(recording engineering standards)Equalization that provides the proper equalization for a Phono cartridge. As per the other post, yes, it will sound very low, and unnatural sounding. If the input you are plugging the turntable input into, doesn't say Phono, you can purchase an inexpensive Phono preamp made just for this very issue. You can try Radio Shack, or find something of better quality on the Internet.
Regards,
Dave
Posted on Oct 09, 2012
richie46
  • 12962 Answers
SOURCE: Pioneer DEH-P4100 volume is noticeably lower when listening to the radio. Volume normal listening to CD, Aux and USB. Small external amp controlling sub but that shouldn't affect tuner. What ya think?
The tuner feed is at lower level than other sources. Happens. Unit may have a control for this internally and you might want to check it out with manufacturer of unit.
Posted on Jul 02, 2017
Jul 02, 2017 | Pioneer Car Audio & Video
The volume is noticeably lower when listening to the radio. It sounds normal on CD, Aux and MP3. I know it has a built in amp. Could this be the issue. Thanks.
You have not mentioned what type of radio you have, what car it's installed in, and what other audio equipment you have. I will assume it's an aftermarket radio, and it's common that the tuner's signal strength is not going to be as powerful as the other sources. If the built in amp is used, then it's used all the time, with all sources, including the tuner. Some brands will have a loudness offset function wherein you can lower the power output of the CD/Aux/MP3 inputs to volume match the radio, but there's no fun in that. There's not a way to make the tuner play louder, unfortunately, aside from adjusting the volume when using the tuner section. Technology has brought many advances, including a much higher signal to noise ratio, which is why digital trumps analog in this instance. This is what you are experiencing, which is not necessarily a technical issue, but a technology issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 02, 2017 | Car Audio & Video
Bought a Dual model XDM280BT having trouble get it wired right. Have a red wire with no corresponding wire to match to
Red wire should go to the ignition switched wure. Need to know what year make and model car
Aug 14, 2016 | Cars & Trucks
Volume fluctuations
Does the volume fluctuate through speakers?
Feb 19, 2016 | Marantz Audio Players & Recorders
I have the xdvd710 when i start my truck up volumn is blastin every time!!!!! how do i get it to stop?????
The dual XDDVD710 RADIO has a volume memmory (it seems), it will go to the last volume setting that it was set to, not play to,(supposly to keep it from blasting you when you turn it on and you forgat u had the volume on blast).
To set it,
1 turn radio on,
2 turn the volume to desire Level you whant it to go when you turn it on (other Levels besside BLAST hopefully) ,
3 push the volume button in, that should do it.
Now you can play your music loud and should you forget that you had it on BLAST (to over come road noise) when you last played your radio, it should start at the preset volume.
Dec 09, 2010 | Dual XDVD8170 Car DVD Player
Tuner Keeps Turning Off when a Loud Noise is Played
It's a receiver, not a tuner.
Clearly something is overloading it or forcing it into self protection.
What else is drawing power from the same souce as the receiver, or from its convenience outlet. There IS a limit to how much current it will support.
Try checking the speaker connections and their impedance to make sure it's not unacceptably low.
Apr 02, 2010 | Audio Players & Recorders
The recorded volumes on my Jazz HDV178 are to loud and distorted. Is there any way to lower the recordeing level?
Yes it is loud because original can do ur work properly not local recorded volumes can not play clearly
Jul 08, 2009 | Jazz HDV-188 Camcorder
Audio fluctuating
Jun 30, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
211 people viewed this question
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
