SOURCE: no power
Unplug the tv press power on and plug it back in.
some of these units have a reset clearly marked on the back.
connect direct to wall as the surge protector may now have issue.
SOURCE: Wii completely stops working after power outage
I just had the same problem as everyone else. I had a brief power loss and our new Wii system's power would no longer work. To fix the problem, I unplugged everything from our Wii and unplugged the power cord from the outlet. I let the system set for 10 minutes and re-plugged the power only. That did the trick. Then I was able to plug everything back up and we are now back to playing.
Supposedly, doing the steps above resets the Wii according to the Nintendo online trouble shooting guide.
SOURCE: presario 2200 won't turn on after local power outage
Hi Mellisa,
If there isn't any lights on the laptop when it is plugged into the mains supply there is a power problem.
Check the surge protector, has got a reset button?
Plug a lamp into this surge board, if the lamp lights up when the board is connected to the mains then the surge board is OK.
Next check the laptop's power adapter with a multimeter, the voltage reading should be as per the label on the adapter. If the voltage is less than the voltage on the label, then it is faulty and needs to be replaced.
Borrow another adapter to connect to your laptop to see if it powers up or take it to your friendly computer shop to test it.
SOURCE: Hello, my HP Pavilion desktop
You may have to change its power supply however, try this first
1. change your UPS coz the old one may have been damaged.
if that still didn't work, change your power supply
SOURCE: TC-P50S1 will not power on after power surge
try unplugging from power for at least 30 seconds. if that doesn't work, it may be a fuse. see the picture for the fuse location.
