Question about Frigidaire Kitchen Ranges
F16 code for Frigidaire Professional electric range comes on interrmitently and goes away after power disconnect. What should I do?
Posted by Bob Drapkin on
Tony Marley
    Habit-Forming:
    New Friend:
  • 87 Answers
This is going to require a new EOC, which is the control board. I attached a link that may help.
Posted on Feb 09, 2019
5 Related Answers
reg501
Richard
  • 413 Answers
SOURCE: pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Posted on Jun 10, 2008
Anonymous
SOURCE: Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
Call the manufacturer. Chances are it's a common problem and they already know about it.
Ben C.
BensDiscountSupply
Posted on Nov 04, 2008
Philip
  • 949 Answers
SOURCE: my frigidaire electric range had a f1 code come
The F1 code is a failure of the ERC (electronic range control), the only fix would be to replace the control board.
Posted on May 17, 2010
taran_2005
taran_2005
  • 10515 Answers
SOURCE: Electric Range Frigidaire Professional Series
The last expert is correct.
According to the Frigidaire technical documentation, most likely the cause of the problem is a bad Electronic Oven Control (EOC).
Check the wire harness and the P4 connector at the EOC. If the wire harness and the connector are fine, replace the EOC
You could try to disconnect the power supply for few minutes, say 15 minutes and see, if that could help the situation unless you need to replace EOC/Clock/Control board.
I don't think it is sensor as this is a common problem on these units and 99% it is faulty EOC.
Let me know,if needed further assistance.
Note - Kindly perform the repair, if you have prior appliance repair experience. These ovens are quite dangerous to work. It could not only damage the oven but could also harm you,if done in an appropriate way.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 18, 2010
ray gallant
  • 67996 Answers
SOURCE: What does F16 mean on a frigidaire gas professional range?
Google it
Posted on Oct 30, 2016
FRIGIDAIRE ERROR F16
Disconnect power, wait 30 seconds and reapply power. If fault returns upon power-up, replace EOC. Electronic oven control or get a new oven.Goodluck)
Jul 20, 2016 | Frigidaire Kitchen Ranges
Frigidaire stove model #FGGF3054MF OVEN GOES OFF IN ABOUT TWENTY MINUTES AND 2.30 COMES ON THE DISPLAY
Good Afternoon friend, thank you for your post!
I see that you are having some difficulty with your Frigidaire range displaying a 2:30 and cutting off. This sounds like a wiring issue or a control panel problem within your range. I would recommend performing a reset and you can do that by disconnecting power to your range by flipping the household circuit breaker and leaving it off for roughly ten minutes. If that does not help to resolve the issue I would suggest having a professional technician come out and accurately diagnosis your range. Best of luck! -Matt
Feb 13, 2015 | Frigidaire Kitchen Ranges
F11 error code
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Dec 14, 2014 | Frigidaire Kitchen Ranges
Error E52 on frigidaire affinity
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Aug 06, 2014 | Frigidaire Affinity Series FASE7073LA...
Frigidaire electric range es530 i have Er on my front right burner it will not come on at all.
Hi Shawna, thank you for your question! ER is commonly refers to a generic error. You may try and reset the range by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Aug 02, 2013 | Frigidaire Kitchen Ranges
What does err F1 mean?
Hello - Typically error code F1 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 30, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
We are geting a F 11 code on this Model number plgfmz96ecc
Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
F11
Shorted Keypad.
1. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
Jun 13, 2011 | Frigidaire PLES399EC Electric Kitchen...
Getting an error code F1 and F3
F1,F3,F9 codes mean.
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
Dec 16, 2008 | Frigidaire FEF366 Electric Kitchen Range
Instructions for frigidaire oven
an f1 one code means that
You can get all the codes here in the manual.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF365BWD&User=&Search=Search
Dec 16, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Kitchen Ranges Logo
584 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
