I have Dayton 3E250 ceiling hung heater. It was originally LP but was converted to NG. I want to convert it back to LP. Does the gas valve also need to be replaced? Thanks
You have to contact the manufacturers rep in the community to verify that the particular model of Dayton heater has the capability of NG to LP conversion. If it is, the natural gas kit will include a new set of brass 'spuds'...typically referred to as 'orifices'....for the main burners. The size of the hole will be considerably larger because NG contains less btu per cubic foot than LP gas.
There will be a replacement pilot orifice for the pilot assembly. Removed and installed usually a 1/2" and 7/16" wrench. This orifice will also have a larger diameter opening.
There should be a regulator to match the 100% redundant gas valve that is in your heater. Note though, that there may be several regulators in the kit to match any one of several brand gas valves that could've been installed on your heater....Robt Shaw, White Rodgers, Honeywell. They will NOT interchange with one another. Follow the directions closely to ensure installation is done correctly...you are working with a volitile, explosive gas !!!!
There may or may not be a set of air shutters to fit over the ends of the burners for primary air adjustment. Natural gas may require a bit of air adjustment to get the proper flame.
Thoroughly leak test everything when done, then leak test again.
If you feel you are in over your head, you probably are so contact a reliable service organization to do it instead. But at least you now have an idea of what is involved.
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
That heater was not designed to be safely converted to Natural Gas. Even if you could convert it, it would cost more to do that than to replace the heater.
