Kitchen Appliances - Others Logo
J
Jeanie parent Posted on Dec 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Salton variable temperature kettle 1'7 litres. Model JK1657 Do you sell the heating element? Thank you.
Terry
Level 3:
  • Salton Master 11,377 Answers
  • Posted on Dec 19, 2018
Terry
Salton Master
Level 3:
Answers
11377
Questions
Helped
4618646
Points
152765
The last page of the manual for it shows the phone number and address.
Click on and go the link below:
https://salton.com/wp-content/uploads/2016/04/JK1657-Booklet-EN.pdf
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 23, 2008
SOURCE: Salton ICM- 1
See if you can find it here...
http://www.pickyourown.org/icecreammakermanuals.htm
Anonymous
  • Posted on Mar 03, 2009
SOURCE: Russell Hobbs kettle element model 10413
The only way to get hard to find Russell Hobbs electric kettle parts is from Russsell Hobbs. They will not sell any parts that are in short supply or becoming obsolete. Please visit their website, follow the instructions for repair and send the unit to them.
Anonymous
  • 496 Answers
  • Posted on Sep 22, 2009
SOURCE: Good afternoon,
Hi Roy,
Here is a toll free number to DTX International. With the model and serial info, I'm sure they can assist you in a replacement part:
DTX International
9855 North Front St Mancelona, MI 49659
1-800-665-0728
Hope this helps... Good luck!
Anonymous
  • 9 Answers
  • Posted on May 23, 2010
SOURCE: MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
mnwarfield10
mark warfield
  • 453 Answers
  • Posted on Feb 23, 2011
SOURCE: RH end element was not heating to same
the new version has a plastic cover over element wires its best just to change all elements to solve this if you have had this toaster a wile the old elements dont have it,,,make sure its correct ones fitted as they are all different watts ..
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
HOW TO PREPARE POPCORN IN SALTON POPCORN MAKER MODEL PCST22Y
This is the typical measurements for salton poppers
for 3 quarts/litres of popcorn:
1 tbsp. (15 ml) of oil
1/3 cup (85 ml) of popcorn kernels
1 (15 ml)* of butter margerine
Filter for salton kettle
The filter for a Melitta MEK17W or Toastmaster TEK17W (identical kettles)are the same.
If you still have the old original filter, here is the link to an inexpensive and permanent repair option using stainless mesh:
www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
2answers
Where can I buy a new scale filter for Melita kettle MK816L I live in the Pickering Ontario area. Thank you
Hi supergran27 :-),
Here's the phone number and location of Salton agents nearest to you.
Pickering Town Centre
1355 Kingston Rd. #70
Pickering, ON
L1V 1B8
Phone: (905) 421-9864
For other agents in Ontario region, click on the link below.
http://www.salton.com/customer-care
Best wishes,
Graeme.
Kettle doesn't heat up and no light comes on when press the On button
Check the obvious, 13amp fuse, if intact connect a multimeter switched to ohms across the live and nuetral pins of the plug (not plugged into mains) the reading should be between 0.05 ohms and 1.5 ohms if higher the element has burnned out or the over temperature sensor has activated. to determine which you will need to open up the bottom of the kettle and expose the wiring. using the above multimeter with the same settings locate the heating element this will have two terminals protruding from the water compartment thes will have eithe screw or spade connections, connect the multimeter across these two terminals and check for the readings above if correct the problem is the over temperature sensor if not then the problem is the heating element. the over temperature sensor will be a circular disk with two terminals clamped to the underside of the water compartment.
Top Salton Kitchen Appliances - Others Experts
Kolbrun...
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
