Question about LG Dishwashers
Hi Fixya, On my LG LD-14AT3 dishwasher 12 yrs old had "OE" error on startup. Chkd filter n drain hose. All clear. What could it be. Thanks Al
Posted by Altaf on
5 Related Answers
james klgr
james kilgore
  • 362 Answers
SOURCE: ge dishwasher is 12 yrs old. water doesnt drain, checked trap, its clear..
check the pump and motor to see if it is working the motor might run but the pump could be to weak to move the water, and the opposite the motor could be to weak. if you hear the motor run then its a fairly simple test put a small rag in front of the intake to the pump and carefully move it close to see if the pump tries to pull it in dont let it suck it in that will cause lots of problems.
Posted on Dec 09, 2007
Anonymous
  • 171 Answers
SOURCE: LG Dishwasher LD 2060SH OE Error code Draining problem
Hi sonicmule,
I'm Harvey the Master Plumber.
Your question is: Re-circulation pump was replaced under warranty after 7 months. Now there appears to be draining problems. hose not kinked and filter seems clear - I guess the pump is either broken or something has jammed it. Does anyone know how to get at it??? Warranty has expired and a new pump + fitting is gonna be expensive. Any tips?
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. The unit must be removed to access the pump. You might consider utilizing our Repair Directory to find a repair man.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Jeff Meyer
  • 423 Answers
SOURCE: LG 6810ST Dishwasher- OE Error Code
SInce the drain hose is not plugged or kinked, the next step if to remove the filter that is beneath the lower rack done in the sump area. Remove approximately 10 phillips screws.
Inspect for debris in the mesh filter and underneath it, especially the drain outlet.
Reassemble and retest with a quick cycle.
If problems persist, suspect a failing pump motor. Schedule professional repair is recommended.
Posted on Mar 30, 2009
Mukesh Kumar
  • 3230 Answers
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Posted on May 06, 2009
Anonymous
SOURCE: LG Dishwasher Model LD-4120M Error 0E
LG 2050 error 0E error. - You may not want to believe this but it is true!!
My dishwasher has failed with 0E error 5 times now - it has cost me R350 each time - the problem IS NOT necessarily a blocked drain hose or the drain pump it could be the thermostat micro switch!!! the thermostat is located at the rear of the right bottom side of the dishwasher(held by oval nylon plastic housing). Turn the machine off. remove the right side panel.(remove top {2screws in lid at back}, remove right panel screws {2 behind door, 3 bottom back panel, 2 behind panel below door {pull panel out from top [no screws pushes in & out of place]}. Locate oval nylon/plastic shape located as above - micro-switch is in the middle (3 wire connectors in 1 block) thermostat is 2 connectors ( 1 each side of micro-switch). use screwdriver to push thermostat back into the nylon housing on both sides (it has worked its way out a bit over time and stops the micro-switch working). Reassemble and dishwasher starts to work again!!!!
Good Luck - Alan
Posted on Oct 31, 2009
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 11, 2010 | LG 24 in. LD-12BW5 Free-standing...
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error OE
thats a drain problem , blocked drain hose , drain pump stuck or burned , last case scenario electronic control
Jun 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
DISPLAYING OE ERROR CODE
What did the original poster with the OE error find?
An OE error = Dishwasher not fully drained out in spite of 5 min. drainoperation
Remove the cause of kink or block in the drain hose.
Remove the filter and confirm that there is no debris in the sump area, especially the drain pump outlet.
Check the wiring connections, especially in the wiring harness in the door panel. Look for "melting" insulation.
Measure the electric resistance of Drain Motor. (good=20-40 ohms) Replace the Drain Motor if out of spec.
Good Luck!
Jan 12, 2009 | LG 24 in. LD-12BW5 Free-standing...
Lg - LDS5811ST Dishwasher OE Error Code
hi
May 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Error
The ?OE? indicates drainage trouble. It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 16, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
102 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
