Question about Dual Video Game Consoles & Games
I have a DUAL 280bt and it is not responding to controls
Posted by Ted Adams on
1 Related Answer
fathitkf
Fathi Elmahdi
  • 1871 Answers
SOURCE: PS2 dual shock controller not responding
that means you have to get it to a repair shop or just buy a new one !
Posted on Jan 11, 2010
Brand new Sony dual shock 3 analogs not responding like my other ps3 controllers
Take it back to the shop if it is under warrantee. Don't mess with it and destroy your warrantee.
Mar 11, 2014 | Sony Dual Shock 3 Controller for...
Wolf dual fuel range keeps beeping after a power surge. Can not get anything on the control panel to respond.
Remove power for a few minutes...plug back in to see if it responds.
If control panel still doesn't respond...it may be time for home visit by repair guy.
That control panel is the "brains" of the unit...power surge may have fried it.
Jul 23, 2011 | Ovens
Lights won't stop blinking & the controller is not responding
Try re-syncing the controller with the PS3, and make sure the battery is charged.
Jun 24, 2011 | Sony Dual Shock 3 Controller for...
Jan 11, 2010 | Sony PS2 Dual Shock 2 Controller...
I have an Aqualink RS 6 all button control panel. All the lights are on the inside panel and it is not responding. The outside panel origionally was not responding, but is now responding and at least I am...
Check the inside and outside low voltage wiring connecting the control panel. Take inside panel to the outside panel and hook up. You might have a bad wire.
Jul 22, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Options menu dead
hi!there,
well! you can't activate what you want because the button "x" and " triangle" are the function key to move on but because of the pads inside your analog controller on "x" and "triangle"are worn out,there is carbon contactor on buttons has fade out,when ever you press x button no connection is conducting your analog controler.you can change setting on analog controller between x and square depend on you,go to configuration then on dual shock controller menu reset function button,you select a key that will change the function key.
or maybe replace your dual shock controller is the best way,
have a nice day,don't forget to rate me,thank's
Apr 27, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 joystick or ports problem.
Maybe you need a new controller that happend to me one time.
Mar 28, 2009 | Sony PS2 Dual Shock 2 Controller...
When i touched my dualshock controller, i received a series of electric shocks. when i started up my PS2, the controller's red light was on but the buttons and the analogs won't respond. Then, i tried to...
it sounds like your controller has had what is called an elecro static discharge. the only way to fix it is to replace the controller with a new one as it is fried. there is now way for you to repair it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Sony PS2 Dual Shock 2 Controller...
Some buttons do not work in game
Well, assuming FIFA 09 is compatible with joysticks/controllers, in the Options menu of the game, where you change the controls, you should be able to assign those unused buttons to actions.
Hope this solved your problem
- Josh
Oct 20, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Video Game Consoles & Games Logo
78 people viewed this question
Top Dual Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Dual Video Game Console and Game Expert? Answer questions, earn points and help others
