Question about Frost Refrigerators
Defy F640 motor and fan replace but the No frost red light keeps on flickering on intervals then
Posted by Penelope Tombisa on
David Spradling
    Top Expert:
  • Frost Master
  • 10,974 Answers
Possible bad timer
Posted on Mar 08, 2020
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: ceiling fan light the light keeps flickering then
this is due to vibration and the contacts get disconnected now and then from the surface.
i feel that you can sort out this problem by tightening the loosened connections of light.
Posted on Dec 29, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: defy side by side 2002
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 03, 2011
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: Thanks for your service to
were the condensor coils clean when you changed the fan motor? let me know. thanks wally
Posted on Apr 27, 2011
imufo2
Leo Ponder
  • 3773 Answers
SOURCE: GSS20IETA GE Refrig keeps frosting
I would suspect the mother board even tho it is new because if it burned out to start with
and you didn't replace the part that blew it out then the mother board will do it again.
It could br the relay or the compressor or any number of elect problems
Here is a generic sampling of my ideas.
First I would remove the mother board and look for a burnt or black spot somewhere on either side of the board. I would change the defrost Thermostat again just for fun.(Some times they are bad)
Here is some help
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 17, 2011
ray gallant
  • 67004 Answers
SOURCE: Hi I hve a defy f640 side by side frige freezer,the alarm light is flashing.
call a repairman locally
Posted on May 31, 2015
Hi i have a defy f640 SS fridge...the freezer side works fine...but the fridge side is not cold as before...please help
It could be that your evaporator fan motor has broken ... which for some refrigerators results in your symptoms of good freezer temperature and too warm in the fridge side. I am not familiar with your model so there could be other issues.
Jan 11, 2018 | Refrigerators
How do i replace the bulb on my Defy double door fridge F640?
In my opinion, it is very risky job. It may damage your fridge itself if you are not properly aware of that. I prefer a refrigerator mechanic to do this job.
Aug 04, 2016 | Cell Phones
DEFY F640 Fridge/Freezer side by side. The freezer made clicking sound, and green light flicker for a while then stops. Now it is not freezing anymore.
Hallo
It could be the theromstat, clicksen or the compressor.
But I think its the clicksen it is faulty and can't handle the amp stress test I hope for your sake other wise I believe its the compressor.
Regards
May 26, 2016 | Refrigerators
Freezer motor not restarting after it switches off.
Hello Rostakes;
My name is Peter. I am a retired field service refrigeration technician.
When you unplug your unit, then plug it back in you are giving the motor a surge charge with more volts than necessary to run the motor.
A bad evaporator motor will hum. The clicking sound that you hear is the motor fan blade striking something.
You need to check for 2 possible causes:
1.) The back cover in your freezer, that is in front of the evaporator motor and fan is very thin sheet metal and will easily flex. Inspect to ensure that you are not over packing your freezer and pushing against the back cover.
2.) It is common for the evaporator motor fan blade to have interference from icing. Inspect the back cover in front of the evaporator fan for frost and ice. Your freezer goes through a defrost cycle where the unit shuts approximately every 8-10 hours, the defrost heater turns on for about 20 minutes, the unit restarts. This is where they get the term; "Frost Free". If you have frost or ice on the back wall your defrost heater and Bi-Metl need to be replaced.
Due to the limited size of response by the site I can not walk you through the repair procedure for these parts. If necessary submit this repair procedure request to this web site.
Nov 04, 2014 | Refrigerators
Defy f640 wiring diagram
Defy F640 freezer fan keeps switching on and off and does not cool.
Jan 19, 2014 | Freezers
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Dec 22, 2012 | Refrigerators
Refrigerators Logo
99 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
RudeRude
john h
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
