Question about Honda Electrical Supplies
Why is my honda gasoline generator making popping noise while working?
Posted by peace on
JOHN LAPIER
  • Honda Master
  • 2,601 Answers
Lack of fuel or air
Posted on Dec 18, 2018
Generator Guru Parts
    Master:
  • 269 Answers
Hi!
You need to reset the valves.
We made a video to show you how: https://youtu.be/mYrdnPVmaDs
Posted on Jan 17, 2019
john h
    Top Expert:
  • Honda Master
  • 23,424 Answers
Fuel -needs tune up or revving to high [ governor problem ]
Posted on Dec 19, 2018
J Rosado
  • 1,164 Answers
Sticking valves, bad fuel, cross firing, ...
1 Related Answer
dieselgenera
sherlywang
  • 425 Answers
SOURCE: The generator makes a very loud noise from the generator side.
The main noise source of engine is as follows:
Induction noise
Exhaust noise
Combustion noise
Mechanical noise
Cooling fans noise
For more:
https://www.dieselgeneratortech.com/generator-sets/generator-set-noise-source-and-solution.html
Posted on Aug 07, 2018
Honda generator wont start it was running fine.
If you filled the fuel tank with gasoline enhanced with ethanol the fuel may be bad and caused the carburetor to gum up. Also Honda engines have a low oil sensor and from your description of the oil, can cause problems with the sensor and the engine won't start. Try changing the oil first and then adding a small engine gasoline additive that helps with stale gasoline starting problems.
Sep 10, 2016 | Honda Electrical Supplies
Dewalt gasoline generator ..rope does not pull
Try taking the spark plug out and see if you can turn it over.
Feb 16, 2015 | Dewalt Generator. 6000 Watt Portable...
Should i use regular gasoline in 2000 watt generator
It is ok to use 87 octane regular unleaded gasoline in a Honda EU2000 generator. I have been running it in mine for 4 years with no problems. Using the higher octane blends is just a waste of cash.
May 22, 2014 | Honda EU2000i1A1 - 2000 Watt Generator
Model EG5000, one year old;last fire up in March, now it doesn't start. Has fresh gasoline
i'm sure you primed it - or go get a can of ether spray in carburetor
Oct 28, 2012 | Honda EG5000 Generator
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
My 3500 wont idle up when somethings plugged in
It will only idle up under a load if you apply a load and nothing happens the governor, governor shaft, spring, or linkage is at fault. Check to make sure all these are connected and working freely and not binding. This applies to all small gasoline generators.
Aug 25, 2009 | Honda Electrical Supplies
Honda 5500 Generator
If you have checked the stator, rotor and brushes and they appear alright then it is probably a voltage regulator. The honda dealer can run a test and confirm the problem at very little expense. It cost me 25 dollars Canadian to preform the test and it was well worth the money because you cannot return electrical parts and they can be very expensive. Have a great day!
[email protected]
Aug 13, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
There is absolutely no voltage output. What
My generator has a switch to turn on the output, you must turn it "ON" to get power.
Jun 10, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
98 honda accord makes a popping noise on front driver side
check your disc pad they maybe worn out already. then check the disc plate also.
May 10, 2009 | 1998 Honda Accord
Electrical Supplies Logo
253 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Marvin
Marvin
Mike
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
