Here are the settings I found: APN Name Verizon APN vzwinternet Proxy Port Username Password Server MMSC http://mms.vtext.com/servlets/mms MMS Proxy MMS Port MCC MNC Authentication Type APN Type internet+mms APN Protocol APN Roaming Protocol Bearer MVNO Type Alternate Settings APN Name Verizon APN internet Proxy Port Username Password Server MMSC http://mms.vtext.com/servlets/mms MMS Proxy MMS Port MCC MNC Authentication Type APN Type internet+mms APN Protocol APN Roaming Protocol Bearer MVNO Type
SOURCE: apn settings
I have a S4, not sure if its the same but here's what i do to get to APN settings:
First go to settings and tap on the connections tab at the top of the screen. Then tap on "More networks" under the "network connections" subsection. Once there you should see a button for "mobile networks". tap on it and it should bring you to another screen with a button called "Access Point Names (AKA APN). Tap on that and you're there!
Like I said, this is for a Galaxy S4 but I think it would be a similar if not identical procedure for the S3. Hope this helps :)
Press the Menu key and save. Reboot your phone and test your data connection by opening a web page.
mmsmvno.com
/mms/wapenc
SOURCE: What are the APN settings for life wireless Samsung J3 prime
please see the link
3 APN settings for Samsung Galaxy J3
SOURCE: life wireless apn settings for at&t huawei ascend xt2 H1711
APN & data settings
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
Switch 2G / 4G
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
Turn on / off data roaming
Turn on / off mobile data
From - https://support.t-mobile.com/docs/DOC-28547 Network APN Kyocera DuraForce XD
