Question about Samsung Audio Players & Recorders
How do I connect a Samsung tv (Model No. PN59D8000FFXZA to Harman Kardon AVR230 receiver with optical fiber cable
Posted by Rasta on
5 Related Answers
Anonymous
  • 70 Answers
SOURCE: No sound when connecting with a fiber optic.
have you tried a new cable?
Posted on Oct 27, 2007
Kevin Braid
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
Marek Podmaka
  • 127 Answers
SOURCE: yamaha rx-v365 plugged in the hdmi from cable box
You have to configure your DTV input to use optical audio instead of analog dtv audio (red/white plugs). Input assignment should be described in the manual. Come back to me if you have still problems with it.
Posted on Mar 02, 2010
Azrael SRL
  • 11800 Answers
SOURCE: Hi I just Bought a
Yes, you are correct: the only audio output this LG tv has is an optical/TOSLINK one. Just use a fiber cable between the tv and the HK. You use this connection to play on the HK the sound from the tv channel - they selected to use this type of connector because modern HD channels have 5.1 sound while the tv and its possible RCA output connectors are just stereo.
You connect the DVR this way: an S-Video cable and a TOSLINK between the DVR and HK , and an single RCA Composite (yellow) video cable between the HK and the LG tv.
Posted on Nov 05, 2010
Anonymous
  • 41 Answers
SOURCE: I have a harmon kardon
Check that the player's Dolby / DTS is enabled. Sometimes it is defaulted in the player to 2.0 / Stereo PCM. What model Samsung? Those Harman receivers are old favorites of mine...
Posted on Jan 06, 2011
Access optical 2 source
I think you are looking for an optical in input on the rear panel of the receiver.
Dec 27, 2014 | Harmon Kardon Harman Kardon Avr 140 6.1...
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
Hook sound surrond
You probably have to select the optical input from the menu for sources of your component connection. Most receivers allow you to select optical, coax, or plain PCM right/left audio.
Oct 15, 2013 | Harmon Kardon Harman Kardon Avr 135 Home...
Which optical port in the back of the receiver goes to the optical port on the back of my HDTV
The manual talks about that.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-125-Receivers-manual/id/386ci156/t/2/
Any of the three INPUTS if you're bringing sound IN from the TV or elsewhere; or the lone OUTPUT if you want to send audio to the TV or elsewhere.
If the former, consider sourcing the audio from the REAL original source of the program you're watching, most likely a Cable Box. Less cabling and fewer connections to fail.
Apr 21, 2011 | Harman Kardon AVR 125 Receiver
I have a harmon kardon avr 120 and a samsung blu ray player.the audio is connected through the optical cable. the receiver however is only playing 2 channel audio. but my direct tv, which is also...
Jan 06, 2011 | Harman Kardon AVR 120 Receiver
Fiber Optic input
No gots. The 3485 is pre-digital stereo-only.
From the manual, page 19
"You may have observed that the HK 3485 is not equipped with digital audio inputs or surround sound decoding. If you prefer the complete home theater experience, you may wish to consider purchasing a fullfeatured Harman Kardon AVR Series audio/video receiver. However, we hope you will find that using a DVD player with the HK 3485 in smaller settings, such as a bedroom or den, surpasses the audio performance of most televisions, including those with onboard stereo speakers."
Apr 13, 2010 | Harman Kardon AVR 240 Receiver
Fiber optics input not working
you will likely have to access the harmon kardon setup menu and direct the fiber input you are using toward the video or audio source selection which is being utilized along with it
Feb 22, 2010 | Harman Kardon AVR 7000
HI, I just purchased a Samsung LCD and connected my Optical Cable directly from my AVR 20 to the TV but get no sound...it is set for Video 1 but I am told that should make no difference and should contact...
Connect the optical audio OUT on the TV to the optical audio IN on the receiver. Turn the receiver on and set it to input as it was labeled on the connection ("video" or "auxillary" or such). Turn the TV on and set it to an active TV channel (with video and presumably audio info), not to VIDEO 1.
If you continue to have a problem, please provide an update.
Nov 30, 2008 | Harman Kardon AVR 130 Receiver
65 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
