Question about Igloo Cooler Igloo - 10.0 Cu. Ft. Top-freezer Refrigerator - White
I have an Igloo Countertop Ice Maker Model ICE102ST. I need the ice basket, mine broke. Anyone know where I can order one from? I have done extensive google searches, unable to locate one.
Posted by Kristin Rehm on
Chris Huff
    Top Expert:
  • Igloo Cooler Master
  • 6,289 Answers
Https://www.appliancepartspros.com/search.aspx?model=ice102c-silver
Posted on Dec 17, 2018
5 Related Answers
christian nielsen
  • 358 Answers
SOURCE: ice maker
If its broken is probably better and cheaper to get a new one than try to fix it or pay to somebody to do it.First unppluged the fridge take the two scrwes that holds the ice maker to the freezer side wall and another one in the bottom of the ice maker once is loose you'll see a plastic plug ,pull itout and you can take the machine off and put a new one.When installing the new one make sure that the filling plastic tube is right through the hole in the back of the ice maker.
Posted on Apr 25, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Kenmore refg. model # 106.56544400 ice maker
Water valve is a dual valve. One for water, one for ice. Switch the wires to test.
Posted on May 03, 2009
richie46
  • 12962 Answers
SOURCE: Igloo model ICE108. Why does the ice full light stay on when there is no ice in the basket?
Because the ice level sensor is stuck in the full or up position. As long as it is there, the ice maker is shut off and will make no ice.
Posted on Oct 27, 2015
joeaxe
Joseph Coppeto
  • 360 Answers
SOURCE: Hello, I have a portable ice maker model 102C igloo . the machine turns on but will not continue the cycle and the ice full red light comes on. Any answers to this problem are welcome.
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Posted on Apr 29, 2016
iam6fan
Chris Huff
  • 6289 Answers
SOURCE: igloo ice maker won't make ice. what's wrong?
Water valve possibly defective
Posted on Oct 09, 2018
Igloo countertop ice machine says tray is full when empty and will not make ice
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How to clean igloo portable ice maker
Maybe scaling has occured, get descaling chemical to clean it. Also remember to remove the dust accumulate at the condenser..
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Ice full when no ice portable ice maker
There is some sort of arm that fits into the ice tray; when the ice fills up the tray the arm is pushed up and a switch connected to it will open the circuit and prevent any future ice maker operation(s). That switch has to be closed for unit to work!
Nov 12, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Mar 30, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Igloo Cooler Igloo - 10.0 Cu. Ft. Top-freezer Refrigerator - White Logo
255 people viewed this question
Top Igloo Cooler Freezers Experts
Bill Boyd
Renee Knafel-Bullock
J Rosado
Are you an Igloo Cooler Freezer Expert? Answer questions, earn points and help others
