SOURCE: iNFOCUS LP 425 DLP PROJECTOR PROJECTOR
try to restart the pojector & the pc, &
check the connection of the projector, some projector needs to warm up before it goes to work..
SOURCE: i need the infocus LP 500 projector driver
Here is the InFocus Site pertaining to your projector.
There usually aren't drivers for projectors, When you connect a projector to your computer Windows,
(assuming that is what you are using) see's it as another monitor. Start the computer with the projector plugged in to the second graphics port. Right click the desktop/properties go to settings tab. On the second monitor adjust the resolution to whatever the native res is on the projector is. That should do it.
Post back with more details if you need more.
SOURCE: Infocus In24+ driver?
IN24 does not require a device driver it utilizes the video display drivers built into the Microsoft Windows OS. You should be able to simply connect the PC/Laptop source to the input VGA connector on the projector then project.
Make sure to toggle your PC/Laptop to output out of the VGA port otherwise it will not send data to the projector
SOURCE: black and white image on infocus x3
first reset the settings to factory default (menu, settings). if that changes nothing and the colorwheel is still in tact, the main board is bad.
SOURCE: I just replaced the lamp on an Infocus X10 DLP
This is seemingly a common issue on the IN82 (which I've also had) and is usually resolved by switching off the 'BrilliantColor' setting in the menu.
