Question about Bosch Ovens
How do I replace the computer circuit board on the top of a Bosch HES7282U/03? Specifically, removing the oven selection dial from the front.
Posted by Debbie Lane on
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Replacing oven thermostat GE XL 44 (WGBS23WEA6WW)
i cannot look up the part diag. for the model you provided( no model exests), but for the most part, its a mater of unscrewing the burner heads fromthe maintop to allow yo to lift teh top further back, by lifting without uinscrewing them, you runn the chance of kinking/ loosing the gas fittings leading to them. In which case yooull wind up unscrewing htem anyway to repair the leak. As far as the capillary tube, it shoud push right through te opening in cavity where old one comes out
Posted on Nov 27, 2008
Anonymous
SOURCE: bosch oven heater ring replacement
Hi, the fan is held in place with a left handed nut, once undone, then remove the steel drive washer by giving it a light tap, finally it is a case of shear brute force applied evenly. All you need is a 10ml spanner and a medium size cross head screwdriver plus a bit of muscle.
Posted on Feb 18, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
Thank's,
macmarkus :)
Posted on Jun 18, 2010
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: I have a Bosch built-in
Welcome to FixYa,
I'm looking at the diagram for your oven and I do not see a P17 connection, however you said it is a connection on a relay. Can you identify which relay it is connecting to i.e. K5, K3, K7 or K8 ?
K5 is the bake element or "DE" ( down ele. )
K3 is the convection element or "RE" ( ring ele. )
K7 is the inner broil element or "RE" ( internal up ele. )
K8 is the outer broil element or "EUE" ( external up ele. )
I should be able to help move you forward in this regard if you can clarify this matter. I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Dec 02, 2010
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: Need to replace my oven selector switch on my
My apologies - I submitted this last night but upon checking for any reply from you, I noticed it had not been posted on the page. I now have to write the entire message again!
Obtaining the part is easy, however fitting it is going to be somewhat more difficult as it's a double oven - meaning it's both higher and heavier. Access for replacing the switch and removing the front panel is from the top so the oven will need to be pulled out from the cabinet or removed. However, the double glass doors make the oven rather front-heavy so it's inclined to topple forward!
This is an expensive appliance and I recommend getting this job done professionally. Should you decide to do the job yourself, you do so at your own risk and you should follow all of the saftey instuctions carefully.
The best - and usually cheapest - place to get any genuine Bosch part is directly from Bosch. They normally deliver in 2-3 working days. The Bosch part number you need is 602732:
http://www.bosch-eshop.com/eshop/bosch/gb/prodlg.htm?Maktx=602732&eshoptype=A&autoselected= £19.63 inc. postage
Click on "Add to Basket" and then "Finish and pay >"
Fitting instructions:
I prefer to do this job with the oven fully removed from the housing but it's probably hardwired to the switch/breaker and needs two people to lift it out. Not removing it also means you have to work at a much greater height, so I recommend complete removal, if possible. The job can be done with the oven only half pulled forward from the cabinet, but the front of the oven needs to be fully supported after pulling it forward or the weight of the doors can (and will) cause it to topple forward.
1. Power off at the breaker/main switch. If you are going to completely remove the oven, you will need to power off at the main fuse box and then remove the oven power cable from the switch.
. Remove the screws which secure the oven to cabinet - these are at the sides and are only visible with the doors open
. Pull the oven control knob off of the fascia panel.
. Remove the oven completely or pull it forward half-way (see above)
5
. Remove the front half of the top panel of the oven. I think it just unclips on these, but there may be a couple of screws to remove at the side first. You will now have access to the switch area.
6
. Make a detailed note of how all the wires are attached to the main oven switch. It's a good idea to take a digital photo for reference. Some of the wires are the same colours so make sure you don't get them mixed up. Also, some of the terminals on the switch are double, so it's best to draw a diagram and give all the terminals numbers and record which wire goes to each one.
7
. Detach all,the wires from the oven selector switch. There is another white "box" attached to the back of the switch, but you don't need to disconnect the wires from this. This box is the thermostat which is attached to the temperature probe in the oven with a long wire.
8
. Remove the screws securing the selector switch to the oven and detach the switch. Make note of how all the parts - switch / bracket / support, etc - fit together. Another digital photo may be useful here.
9
. Unscrew and pull the thermostat out from the back of the selector switch. You should now be able to remove the switch from the oven.
10
. Assemble the new selector switch with the bracket, support, thermostat, etc and secure it to the oven.
11
. Refit everything else in reverse order of the above.
This may be a little bit more complicated than you were expecting. If you don't feel confident to do the work yourself, then please seek professional help. If you do decide to DIY and you let me know when you are planning to do it, I can try to be online to assist you if you get stuck anywhere.
Merry Christmas!
BElectric
Posted on Dec 20, 2010
Bosch oven will not turn off
New oven? What about the supplier warranty? Bosch is a top make, get hold of a dealer.
Nov 14, 2014 | Ovens
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
No I see double wall oven
I have a B50STIP/1 wall oven who oven selection dial has worn away.
Can someone please tell me what is on the dial at 5.00 oclock?
Thank you ,
Liz
Jul 13, 2013 | Ovens
Need to replace my oven selector switch on my bosch oven HBN13M55OB/03
5
6
7
8
9
10
11
Merry Christmas!
BElectric
Dec 18, 2010 | Bosch Ovens
My thermador oven display does not work. I am told that i need a new computer board. is that easy to remove and replace?
Yes,
Very easy.
Pull the stove out from the wall, unplug it.
remove screws at the back of unit.
This should expose your dials and computer board
Aug 05, 2010 | Ovens
Main Oven Overheating
Try putting thermoter in oven take off main dial you well see a small screw ajust slowly and check every 30min.tell temp is correct.and put dial back on
Jul 26, 2010 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
My bosch double fan oven has cut out and has blown the fuse
there is a little control board that might be defective on .
Feb 24, 2010 | Ovens
Ovens Logo
Top Bosch Ovens Experts
Marvin
Marvin
Paul Carew
Michael Thomas
Michael Thomas
Are you a Bosch Oven Expert? Answer questions, earn points and help others
