Question about Electrolux Washing Machines
The EHO (or EH0) error indicates a problem with the incoming power or an electrical problem inside the washer. Unplug the washer for a while to reset the error code. Next check your wiring and make sure that the outlet doesn't have a fault. If you live in an area with brown-outs or wires that touched during a storm, wait until the electricity is repaired. Then check if the power supply to the washer was damaged by the surge or changing power levels.
If these aren't responsible for the problem, you'll need to check the wiring for shielding damage, the wire harnesses and the rest of the washer. There is a parts diagram here: http://docplayer.net/60693214-Spare-parts-list-household-washing-machines-pnc-elc-brand-model-market-electrolux-ewf10842-th-washing-machines-front-loaded.html .
I hope this helps.
Posted on Dec 17, 2018
SOURCE: Electrolux Gallery Dishwasher Error Message AL3
It sounds like it could be a heater problem, I would check this first
Posted on Nov 27, 2007
SOURCE: Hi,
First of all is the machine doing anything it should not be.That alarm code does not exist on our system,the closest is EH1 and this relates to Power supply problems or a faulty PCB.To cancel press and hold the start/pause button and the nearest option button for about 5 seconds,now turn the programme knob to position 10 then hold in the start/pause button and option buttons again till alarm disappears and E00 is showing.Then turn dial to 0 then back to position 1 then back to 0 to cancel operation.
Hope this helps.
Posted on Jun 01, 2010
SOURCE: what does error code EHO mean
That error code does not exist,the closest is EH1.which means that the supply to the machine is incorrect.What is the model,and PNC.number,hope this helps.
Regards.
Posted on Jul 02, 2010
The power supply is failing and needs to be replaced but first try the steps provided in the link below. Washing machine displays error message EHO EH0
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Posted on Feb 17, 2018
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
