Question about Precor Exercise & Fitness
My Precor 964i won't allow me to set a time greater than 10 minutes and will not allow me to enter Club mode
Posted by Malcolm Wilson on
CisnerosNickie
    New Friend:
  • 14 Answers
II just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site: http://S­­­­­­a­­­­l­­­­a­­­­r­­­­y­­­­­­H­­­­D­­.­­C­­o­­M
Posted on Dec 16, 2018
Testimonial: "The answer I received from this person was: 'so waht'! Not helpful"
3 Related Answers
Anonymous
SOURCE: takes a long time to down load game settings
I found this on another help site for getting the same thing. I tried this tonight when I was stuck in the Dowloading Settings and it worked for me. Not sure if it was coincidental that it went online after I finished this or not...but it got me online after 2 days. Here is what to do...
"another solution is.. go to barracks, leaderboards, kills and hit change filter so the worldwide kills screen is up turn ur controller upside down and let it scroll up for about a 15 mins - 30 mins . then hit O 3 times to get back to the original menu and do fins game.. this worked for me on 1 account but not on another.. if u have nothin else to do try it.. cuz this stupid error was annoying the bleep outta me."
Posted on Mar 01, 2009
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Precor C846i bike-cannot access Club features to make changes
adjust the magnet with the bolts, and move and tight very well.
2) proof the magnet with the magnet from your refrigerator for attraction and repulsion, if doesnot pass the test replace the magnet.
and proceed according with common sense.
God bless you
Posted on Jul 23, 2012
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Engine stops running and won;t restart until setting idle for about fifteen minutes or longer
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Posted on Aug 29, 2012
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
How to change precor932i lenguage
When start-up prompt "PRESS ENTER TO BEGIN OR PRESS QUICK
START" appears, access the Club Program by sequentially pressing
STOP, SPEED , SPEED , SPEED , RESET, SPEED , SPEED , and
SPEED . (Numbers on the display appear in sequence: 4, 5, 6, 5, 1, 5, 6,
and 5.)
Note: You must sequentially press each key within 4 seconds of each other
or the display reverts back to the start-up prompt.
6. Maximum Speed: Use any or key to designate a speed limit between
1 and 15 mph (1 and 24 kph). The speed you designate limits the speed of
the treadmill. Press ENTER when the desired speed appears.
7. Maximum Workout Time: Use any or key to designate a time limit
between 10 and 240 minutes. The amount of time you choose limits the
length of a person's workout. (This does not include the automatic 5-minute
cool-down period.) Press ENTER to accept the time limit.
Note: Continuous pressure on the arrow key lets you scroll through the
numbers being displayed.
8. Language: Use any or key if you want to change the language. You can
choose between English, German, Spanish, or French. When you change
the language, you affect all the prompts and informational messages that
appear on the display. Select the language being displayed by pressing
ENTER.
9. Custom Courses (C964i only): The course profile appears in the center
display. (If you want to customize course number 2, press ENTER.)
When you enter custom mode, you have the ability to "draw over" an existing
God bless you
Feb 22, 2013 | Precor 932i Treadmill
E203 error message when i press start button
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Quinton Treadmill E203 Error Code
Jan 09, 2013 | Exercise & Fitness
Password reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Aug 24, 2012 | Precor 9.31 Treadmill
Quinton treadmill error 203
5. Motor.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Jun 16, 2012 | Exercise & Fitness
How do I change time on a KADIO clock 3809
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
C956 precor treadmill
Hi
not to sound funny but are you sure that you have this tread set in the units (mpg/kph) that you require. i have worked in loads of gyms and its a common problem that people think the belt is running to fast because its set in kph and that thinks its in miles eg 9mph = 14.5kph
you can check and change the units in the club setting menu.
hope this helps :)
Jan 07, 2010 | Precor C956i Treadmills with HR /...
I have a holiday living power stake timer, how do i program it?
I have the directions for this item and tried to paste them here, but exceeded the amount of space allowed. Will send in several replies. FIRST:
HOLIDAY LIVING HEAVY DUTY OUTDOOR DIGITAL POWER CENTER
MODEL #LW28080 ITEM #0050024
INSTRUCTIONS:
NOTE: To set up Timer for the first time, plug in the timer for 10 minutes, then insert a sharp pointed object or opened paper clip into the pin hole marked "RESET" to clear all settings.
SET THE CURRENT TIME
1. Press the CLOCK button.
2. Press the DAY button to set the current day of the week.
3. Press the HOUR button to set the current hour. Be sure to take note of AM / PM.
4. Press the MIN button to set the current minute.
5. Press the ENTER button to finish setting the time.
Note: If you do not touch any buttons for 10 seconds, it will automatically save the time.
Continue to Digital Timer Mode or Photocell Timer mode below.
To have your lights turn on and off at specific times throughout the week, choose Digital Timer Mode.
To have your lights turn on every day at dusk and off at dawn or after 1 - 12 hours, choose Photocell Timer Mode.
Nov 21, 2009 | House Brand Hardware & Accessories
How to change turn-off time from 20 minutes?
Power Save mode allows your machine to reduce power consumption
when it is not in actual use. You can turn this mode on and select a length
of time for which the machine waits after a job is printed before it
switches to a reduced power state.
1 Press Menu until System Setup appears on the bottom line of the
display and press Enter.
2 Press Enter when Machine Setup appears.
3 Press the Scroll buttons until Power Save appears and press
Enter.
4 Press the Scroll buttons until the time setting you want appears
and press Enter.
5 Press Stop/Clear to return to Standby mode.
Jun 28, 2009 | Xerox Phaser 6110 Laser Printer
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
Exercise & Fitness Logo
49 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
