Question about Alba Televison & Video
SOURCE: TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
Posted on Nov 26, 2007
SOURCE: alba portable tv tuning set up?
its stuck on the same channel it says red gain at top of screen its not responding to remote control
Posted on Nov 03, 2008
use a scart lead connected between your digital receiver to your tv
Posted on Jun 03, 2009
SOURCE: I need a manual to tune in a Alba LCD 19880HDF
Quite often with different TV, the built in tuners are different, so even though you may have been able to tune in automatically with one you can't with other tv's as there tuner isn't so good, you may want to look at getting a bigger aerial as the 1 you have may not get a strong enough signal for the tv tuner.
Posted on Nov 26, 2009
Testimonial: "thank you, will try that tonight"
SOURCE: I bought an Alba CDVB4 and the remote isn't right
Hi
Not sure if you found the problem for this, but I had the same problem and couldn't find any reference to this except your question so thought I would put up an answer in case it can help you or anyone else.
Aparently, Alba have got hold of the codes that Toshiba use for their remote controls, so if you have a Toshiba telly an Alba product like this won't work. The only solution being to return it and get a different make.
I returned mine twice for a straight exchange thinking it was just a manufacture fault before I found this out. I then exchanged it for a Bush set top box - only a fiver more - and it now works PERFECT!
I hope this helps some.
Zoe
Posted on Feb 21, 2010
