Question about Electrical Supplies
I need a wiring diagram for a powerte,ch 12v 2oa dc dc charging regulator no mb 3684 20 amp?
Posted by Chris Guise on
Ron Rak
    Habit-Forming:
  • 138 Answers
1 Related Answer
Anonymous
  • 30 Answers
SOURCE: wiring diagram for body mount voltage regulator
http://www.ncttora.com/fsm/1993/index.html
Posted on Aug 08, 2009
I have problem with my aura classic 110 for my charging system.what is the skematic diagram of the rectifier?
Hi, Josephine before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
5. Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
kawasaki aura classic 110 wiring diagram Google Search
GY6 scooter rectifier regulator
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Spare parts for Kawasaki AN110
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 07, 2017 | kawasaki Motorcycles
2009 Hero Honda Passion Plus charging system
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Electrical Modification on Hero Honda Passion
How to Test Your Motorcycle Charging System
http://fullmanuals24.com/brand/hero-honda
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Jul 04, 2017 | 2009 Hero Honda Passion Plus
DOES THE FORD TAURUS HAVE A VOLTAGE REGULATOR
Every car ever made has a voltage regulator
The alternator is just that-- AC Current that is rectified
to DC-- to run the car & charge the battery
Just about every car for the last 40 years has the
regulator inside the alt
How it is controlled varies from manufacture,make,
model,year,etc
You can not charge a defective battery
You may have external issues that provide
regulator control,even a bad ignition sw on
some cars,or module control of regulator
Need a wiring diagram & a good amount of
knowledge to resolve your current problem
Jan 24, 2013 | 2001 Ford Taurus
Wire diagram for chevy 3500 van
When you say charging,do you mean amp reading or volt reading?Amps should rise when first started then drop.Volts should stay close to constant.The small wire going to the alternator to power the regulator in the alternator is just switched power.If the volts fall under 14 after ten minutes you may need to try a replacement alternator.
Apr 28, 2017 | Chevrolet Express Cars & Trucks
How to connect a new era alternator voltage regulator wiring diagram.Or a schematic diagram of the charging system.
knowing the color codes can be a great help..usually in 12v reg system,from the regulator there are 6 white wire having a stripe codes,blue means neutral,green means field,black means ground to body,white means hot wired to +12v,yellow means to bat charging indicator going to instrument panel and finally red means to ignition....and always secure the regulators case to ground.
Jul 19, 2011 | Isuzu i-Series Cars & Trucks
I have a1999 Honda VFR800FI motorcycle. If I fully charge the battery, I seem to be able to ride for about 1 hour or so. Could my generator be bad or something much worse? I'm only getting 12v to the...
G'day,
You say you are only getting 12v to the battery(& I presume you tested this with the engine running) then that is too low.
It needs to charge from about 13.5 to 14.2volts(DC).
Common causes of a low charge rate are,
Faulty voltage regulator.
Faulty alternator(stator usually).
You need to have these items tested to dertermine which is at fault.
Unless your experienced, faultfinding charging systems can be tricky & you need a couple of special tools too do it efficiently.
If your up for it- & have a multi meter,
You can start by disconnecting the wiring at the regulator.
Using the meter set to resistance-ohms times 1- check between the three yellow wires-yellow to one yellow then the other-see you get same readings & should be quite low(just a couple or few ohms)
Now set your resistance scale to max.
Probe between each yellow wire & earth.(don't let your fingers touch the probes-it will give a false reading)
There should be NO CONUNUITY- Any reading between the stator yellow wires & earth means a faulty stator.
As for the regulator- there all different so manufacturers specs are usuall needed.- as are test procedures.
Hope this has helped some what
regards Andrew Porrelli
May 12, 2011 | 1999 Honda VFR 800
I bought a 1986 honda ch150 elite.It did not have a battery so the former owner put in one he had not noticing the and - connections. Fast forward to now. I started working on it and bought a new battery...
Hi, Jwright89 nice novella before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
Stator ground Check:
5. Regulator Test:
Identifying Wires:
Honda Elite CH 150 Charging System Fuse
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Honda CH150 Manual
Honda 125 150 Owner Manual
May 07, 2017 | 2010 Honda Elite
Wiring diagram for body mount voltage regulator
Aug 06, 2009 | 1995 Toyota Pickup
Electrical Supplies Logo
110 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
