Question about Frigidaire Kitchen Ranges
I have a frigidaire gas oven which lights just fine and heats fine but when reheating, there is a roaring sound, a poof sound and a slight smell of gas.
Posted by Lizy on
5 Related Answers
Anonymous
  • 1142 Answers
SOURCE: Gas oven stopped working
Sure i will be able to provide you solution
Posted on Apr 15, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Posted on Sep 30, 2008
Anonymous
  • 13 Answers
SOURCE: gas oven makes a fluttering sound when pre-heating and cooking
This is most often due to the ignitor bar aging. With time it draws less current and does not hold the regulator valve open all the way. You can confirm that the regulator is OK if the broiler works. Replacement for nearly all of these ovens is a universal part, about $35 at appliance parts stores, takes 5-15 minutes to change (depending on whether you need to pull the oven out to get to the connector).
Posted on Nov 30, 2008
Anonymous
SOURCE: Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Posted on Mar 28, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Oven won't turn on, but the stove is fine!
Replace the oven glow bar ignitor.
Posted on Apr 20, 2009
Turn on gas oven; it lights, big poof/pop comes; then continues to light and heat properly. How do I stop it from popping? The pop is scary!! GE Spectra Gas Stove/Oven
The reason it "POOFS" is because the igniter is slightly weak and some gas enters before it gets lit,this will continue and get worse. To resolve it the igniter would need to be replaced and then as soon as the gas enters it would light it right away without collecting before it lit.
GENE
Oct 10, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Apr 15, 2008 | Ovens
Frigidaire oven wont ignite
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 29, 2010 | Frigidaire FGF378AC Gas Kitchen Range
Oven won't light, but if I tap on the box with wires connected to it that is behind the bottom drawer, it will light.
Kitchenaid slide -in-range gas oven KGST307HBS4 will not heat beyond 235 degrees slight smell of gas
Dec 18, 2009 | Frigidaire PLGS389EC Stainless Steel Gas...
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Smelling gas at when stove is in prelight then going away
Welcome tkrogers,
You said,smelling gas at when stove is in Pre-light then going away.
In some stoves this is normal as long as it is a slight smell and it goes away when the stove or oven ignites.
You know gas really has no smell, but this smell is added for our safety!!
What is the Make,year ,and Model number of your range?
The gas must start somewhere until the flame ignites it.
So we smell a slight smell of gas until it burns.
Thanks,
Huuum
Please remember to lave a solved rating before you leave.
Oct 11, 2008 | Frigidaire Kitchen Ranges
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kitchen Ranges Logo
66 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
