Question about Frigidaire Ovens
I have a Fridigaire FEB30S5ABB range double oven. The large bottom oven works fine, but the small upper oven heats very unevenly.
I have checked the element continuity and it is fine, and the internal heating sensor shows a resistance change with temperature. What else should I check? Thanks for any assistance.
Posted by noelkuck on
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Posted on Dec 29, 2007
grandadfixer
Reg Woolley
  • 99 Answers
SOURCE: replace the upper heating element
hi E mail me model no can proberly sort it. [email protected]
Posted on Jun 11, 2009
Anonymous
  • 166 Answers
SOURCE: Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Posted on Feb 27, 2010
Testimonial: "Thanks for thinking "out loud" with me!"
Anonymous
SOURCE: Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Posted on Jul 05, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite 790-99513307 side by side electric
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My double oven , top oven, will not heat. Bottom oven works fine. What do I need to do. Diane Vogeler
Do you have an error code? Check continuity of lower and upper thermostat. Check the elements for continuity. You have two fuses, one on the back of the oven for the elements and one from the oven board, it will probably be in clear plastic. Worst case is the oven board is bad.
Sep 11, 2017 | Ovens
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
I have a Frigidaire Electrolux Model FEB30S5ABB. The oven will not heat up to the correct temperature and the bottom element is not turning on. We checked the element at it checks out ok. What could be...
Hello lizzyd62 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately.
Nov 23, 2012 | Frigidaire 30 in. Electric Single...
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Double oven,the top ovens lower heating eliment will not work-I have relaced it and tried the lower ovens eliment still nothing,the broiler(upper)eliment works fine?
There are some small relays on the circuit board in the area of the controls. These relays are undersized and normally fail shortly after the warranty period. If you are handy with electical work and a soldering iron you can replace the components on the board using standard items from Radio Shack. If not, then buy the circuit board but expect to pay a lot. I once fixed a friend's oven and broiler by putting a low voltage optical semiconductor relay from Radio Shack into the space of each failed mechanical relay. Then I used those to operate large 40A definite purpose contactors -- normally used in HVAC systems. This required addition of a 24vac power transformer. All of it fit easily into the space behind the control panel of her drop-in range. The beauty of the optical semiconductor relays is that they isolated the electrical system of the original circuit board from the additional parts I was supplying. This makes is easy for anyone who works on it later to see the nature of the upgrade/repair.
Dec 12, 2009 | Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
