SOURCE: burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Posted on Sep 18, 2008
SOURCE: Trying to remove motor from wet-dry
Hi Dan:
I am not familiar with this model but some of the consumer wet vac models are build with a module and motor as one part. You will need to replace the entire module
Posted on Aug 08, 2009
SOURCE: removing impeller from sears shop vac
The impellar will screw off with a clockwise rotation and the new one installed with a counter-clockwise movement.
Posted on Aug 21, 2009
SOURCE: shop-vac model 90L550A motor wont run
Yes replacing the link would work, but that would not fix the cause. You have either pulled the wiring to the point of pulling apart the connection or there is a short. Which would be in the way of a grounding effect causing the link to heat and melt. A safty issue to be sure. Check all contact with housing and motor to make sure there is not an underlying problem to start with. Unpluged of course
Posted on Feb 25, 2010
Jan 28, 2017 | Vacuums
Oct 20, 2012 | Shop-Vac Corporation Shop-Vac 9625410...
Dec 29, 2010 | Shop Vac QPMH450 Canister WetDry Vacuum
Feb 22, 2010 | Vacuums
Aug 08, 2009 | Craftsman Vacuums
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Oct 22, 2008 | Shop Vac Vacuums
Sep 17, 2008 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Jun 10, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Jul 26, 2019 | Shop Vac Vacuums
