Question about Laser Office Equipment & Supplies
Hi, My brand new Samsung xpress laser printer wont print on glossy paper, they get stuck every time, no problems with normal paper
Anonymous
SOURCE:
Anonymous
  • 74 Answers
SOURCE: samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Posted on Jul 18, 2008
museumsteve
SOURCE: kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Posted on Oct 10, 2008
Anonymous
  • 5 Answers
SOURCE: kodak 5300 aio printer won't print black
It is the print head. Cleaning the heads does not do any good, either does replacing the ink. What you'll need to do is contact Kodak's customer service line and they can replace it for you free of charge. On this site everyone seems to be saying it is consistently the black that stops, however, based on what Kodak said it is possible that either the black or the color can have this same issue.
When you call in they will ask you for your service number, which is located on the bottom left corner of the machine, when you lift the lid (as if you were going to replace the ink). They didn't ask me when I bought it, how much I used it, etc.
They will set up a case for you - it takes 2-3 business days for the print head to arrive. They will provide you with an invoice number as well. Be sure to document it all just incase the head never comes, or if there are additional issues after you receive it (and/or if it doesn't solve the problem)
Posted on Nov 22, 2008
Sunil Rathod
  • 199 Answers
SOURCE: HP PSC wont feed through glossy photo paper. Paper
hp printer support low gsm photo glossy like 130-170, or only hp photo glossy they have rough back side to run paper properly
Posted on Feb 27, 2009
Anonymous
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Posted on Aug 17, 2009
Samsung Xpress M2875FD Laser reset firmware
download from samsung website,may use foll link:
http://www.samsung.com/uk/consumer/it/printer-multifunction/black-white-multifunction-printers/SL-M2875FD/SEE
Feb 12, 2014 | Samsung Xpress M2875FD Laser Multifunction...
Smearing of printed image in color printing mode
many times this problem is caused by the type of paper being used, especially with photos, try a different paper, or change the type of paper in the print box when you try to print. the amount of toner used is determined by the paper type. if you are printing on glossy paper you might get the smearing if you didn't tell the printer to print on "glossy" Anyway, this is most likely where to problem can be solved. good luck
Mar 24, 2011 | Samsung CLP 300 Laser Printer
I can only print one sheet, then the paper stucks. What do I have to do? I have to open the front door, get rid of the paper and start over. So one more sheet is printed and the paper stucks again. This...
Samsung is a reliable brand, but they have had problems with the vendor for the exit sensor. When it goes bad the paper comes part way out of the exit and jams. The part is less than a dollar, and you might find it at www.precisionroller.com
Jan 22, 2010 | Samsung ML 2010 Laser Printer
How do you print Glossy Photos on a Samsung Color Laser CLX-3160FN printer without the laser buring off the gloss?
Do you have the right type of paper? I suspect the glossy paper you have is for an inkjet and is melting/buring when it is going through the fuser of your laser printer. The same thing for sticky back labels. Unless they say they are rated or compatible with a laser printer, don't use them.
Jun 20, 2009 | Konica Minolta magicolor 2500W Laser...
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Samsung CLP-300 dark prints and smears
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Black smugs on any glossy print
check the fusing area. (where the paper is heated)there is an adjustment for envelop . set it to normal because the pressure on fixing unit is too loose.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Phaser 7300n Printing on Double Sided Glossy Paper
At first I didn't think the paper was the problem, but I looked up the specs on it and is seems to be a paper designed for an offset press.
I suspect after reading the information on the paper that the coating is not designed for the high temperatures of a laser printiers fuser heat of over 350 degrees.
I do suspect the paper is the issue.
sounds like you are melting the coating.
Dec 30, 2007 | Xerox Phaser 7300DN Laser Printer
Printer Jam
Its probably stuck wrapped around the fuser.
It WAS glossy Laser paper and NOT glossy Inkjet paper wasn't it ??
Glossy Inkjet paper could cause a proplem like this, as inkjet paper just isnt made to stand the temperature of a fuser (the fuser cover reaches a temp of just under 180 Celcius) and it melts !!!
Dec 12, 2007 | Samsung CLP-510 Laser Printer
Canon wont print on glossy
This is something only Canon can answer It seems that the perhaps the paper sensor is not doing its job. What Brand/thickness of glossy are you using? May be relevant? Check Canon tech support in the first instance this may be a replacement situation
May 14, 2007 | Canon Pixma MP500 All-In-One InkJet...
42 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
