Need amped per number to replace right one
SOURCE: Need fuse panel diagram for 2002 BMW 325xi
This is what I could find. It doesn't have a steering whee radiol control fuse but has 2 fuses for the radio. It seems to be the same panel across the board for BMW's. 4x4's, diesels, gas, 6 and 8 cylinders, etc. Hope it helps.
SOURCE: 2002 jeep liberty interior fuse diagram
1-20amp-pwr outlet frt. 2-10amp-rear fog lights(export only)
3-15 amp-horn 4-10amp-hedlt low beam rt
5-10amp-hedlt low beam lft 6-20amp-bodycontrolmodule/pwr dr locks 7-spare 8-spare 9-10amp- rt pk lt /rt tail lt/trailer tow lt/cluster
10-spare 11-15 amp-flasher 12-15 amp-stop lts
13-10amp-bodycontrolmodule/cmtc/cluster 14-spare
15-10amp-pdc fuel pmp & auto shutdownrelays/skis
16-20amp-pwr outlet rear 17-15amp-rear wiper 18-20amp-radio choke relay 19-20amp-frt fog lts/trailer tow stop and turn lts
20-20amp-sunroof 21-spare 22-10amp-wiperswitch/frt and rear washer 23-10amp-lft park lt/lft tail lt 24-10amp-pdc blower motor relay 25-10amp-heatseatswitch/hvac controlhead/trailor tow battery charge 26-10amp-hedlt highbeam rt 27-10amp-hedlt highbeam lft
28-spare 29-15amp-heated seat module 30-10amp-heated mirrors/rearwindowdefrosterindicator 31-20amp-cigarlighter
32-10amp-radio/frtdoorlockswitches/bodycontrolmodule
33-10amp-skis/diagnostic connector 34-15amp-cluster/courtesy lts/radio/bodycontrolmodule/maplights/cmtc/underhood lt/vanity lts
35-spare 36-10amp-ignition run/start-orc/lft and rt siacm
37-10amp-ignition run only-orc 38-10amp-abs module/brake shift interlock solenoid 39-10amp-rear window defroster relay/flasher/backup lts
SOURCE: don't know what fuse is what .10 amp blows right
try different fuses starting with lowest then go up but think it is a 30 amp fuse ?
SOURCE: Need to replace a 20
Just take out your fuse box and see the fuse diagram there. If it was removed, just check one by one your fuses by visual check. You should found the blown fuse is disconnected ( melting) inside the body. None of instrument you need to use but visual check only. Then replace the blown one.
Regards, Jay
SOURCE: Have a diagram for the
The 25 amp fuse is for radio amplifier.Click this link for fuse and its slot diagram:--- http://howtobyme.blogspot.com/2011/08/fuse-box-diagram-for-2000-jeep-grand.html ---------- This will help.Thanks.Helpmech.
