Question about Garmin nuvi GPS
I just downloaded the new software on my nuvi 260w i dont know if i get the traffic also.
Posted by barbara lemma on
Marvin
    Top Expert:
  • Garmin Master
  • 85,239 Answers
Contact Gamin support on this.
Posted on Dec 14, 2018
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: I need to register my
To register your nuvi, just go to this link https://my.garmin.com/mygarmin/marketing/register.htm
Posted on Jan 04, 2009
Anonymous
SOURCE: nuvi 260w change to different voice
First you have to down load a new voice. Do this from www.garmin.com. Then you go to settings, language and Voice. Select and save.
Posted on Feb 21, 2009
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: How to change Chinese character to English/Romanise on nuvi 260W
1. Press the wrench (tools) button.
2. Press the Setting (gear) button (upper left).
3. Press the down arrow until once.
4. Press the 2nd row function (language).
5. Press the middle button of 3.
6. Press the up button until you see the function American English and select it.
7. Hit OK.
You should be back to English now.
- Jim
SHARCNET-USA
Posted on May 04, 2009
HarryHarley
Harry
  • 343 Answers
SOURCE: nuvi 260w no power.
Yes, you need to charge it. USE the charger that came with it for best results. Some off brand chargers will NOT work.
You plugged it into your car and nothing? Even if the batteries are bad it should still work. Is it the Garmin charger?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Posted on Jan 13, 2010
HarryHarley
Harry
  • 343 Answers
SOURCE: nuvi 260w system software missing on screen when i open it
Fairly simple to do:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Posted on Jan 17, 2010
Hi - I own a Garmin Nuvi 260w. Is it possible to use the SD card to download a trucker navigation road map and upload this to my Garmin Nuvi 260w? Thanks for your response.
It is possible as long as the map is Garmin compatible.
However even with a trucker navigation map installed, the nuvi 260w will not function as a trucking GPS as the routing and IQ of the nuvi 260w does not have the capability to operate in this manner.
The nuvi 260w does not have a trucking mode to allow for the input of specific truck information like truck and trailer length and gross vehicle weight to use as factors on determining the best route for the specific truck/trailer combination.
I would recommend using a GPS specifically designed for trucking like the Garmin Dezl.
http://www.gpscity.com/garmin-dezl-560lmt.html
Traffic option disappeared
the only time you will see the traffice option is when the unit is plugged into power with the traffic receiver connected
1helpful
Garmin 260W free updated map
Hello.
You can go to mygarmin.com or garmin.com . You have to register. It is for FREE. Then,you can update your GPS. You can also download maps by just following the screen instructions.
You can also find all the software/drivers you need there.
Hope it helps.
6helpful
I want to update my garmin 260w with free updates on the maps. My unit is 2yrs old.
Garmin provides free updates through their website for the first 60 days after a new unit is put into service. After that, you'll have to purchase map updates. (Software updates are free, though.)
That said, you should first point your browser to www.Garmin.com and go through the process of downloading and installing their browser extension. You might have to reboot your computer or restart your browser to finish the installation.
Return to Garmin.com and register your nuvi. At some point, it will ask you to connect your nuvi to the computer via the USB cable. Do so. Your computer will also go through the process of installing the drivers necessary to view the nuvi as a storage device (so you can download photos and the like).
Once everything is up, the browser extension will tell you what the status is of your nuvi and of its maps. If you're entitled to a free map update, it will allow you to do so. If you're due for a software update, you can do that, also.
2answers
Own a Garmin NUVI 260W gps. How can we update this with new map, etc.? thanks.
How old is it and have you updated it once, if so
you might have to buy a update
Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Garmin nuvi system software missing 265W i try to update my garmin nuvi 260. I see on the screen: sytem software missing. I cannot do anything else. Please, help!
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Nuvi 260w system software missing on screen when i open it
Nuvi 260w system software missing on sreen when open
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Update your 260 to the newest software, which is what I think your asking??
System software missing
Current version of software is 5.0
Download that as that may be your problem.
You must download the newest version of WebUpdater from Garmin for free to your computer.
Then:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
