Neither floor or hand accessory attachments will power up. I have not been able to find a wiring diagram for vacuum canister or hose handle. I do not know how to take the hose handle apart.
Check the spout. The plastic piece inside where your hose goes in. Should be 2 contacts one on each side. There should be a little plastic partially covering the contacts. The best way to trouble shoot is to turn vac and power head on and wiggle the end of the hose. Hope this helps. Chris
It is likely a wiring issue, check the continuity of the wires to the brush motor.
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
