Question about Frigidaire Dishwashers
I have a Frigidaire it has power but can't get it to do anything beside light up
Posted by fletcher leggett on
I have a Frigidaire ES 100/105 electric stove that is about 1 year old and has just stopped doing anything - no lights, no heat in stove or on stove top. nothing. I have power to the outlet so it is
Hey friend, I appreciate your post! It sounds like a possible issue within your control panel or a faulty wiring harness. I would recommend seeking assistance from a professional for further proper diagnosis and repair to avoid any unnecessary part purchases. If you need any additional assistance please feel free to reconnect. -Matt
Oct 10, 2014 | Frigidaire Kitchen Ranges
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
Burner not working
Good morning to you
Have you checked the power?
Weather it is on or not as well as cables and plugs.
Some cookers have an automatic thermostat and cuts the power off if things get too hot. then you have to find the bulb (small) which red and push a button beside the bulb and a green light comes on and the cooker is working again.
Enjoy your coffee
kolbrun
Apr 24, 2012 | Frigidaire Kitchen Ranges
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Nothing powers up. no lights come on. it won't do anything
no lights no power means your control board is gone or your machine isnt getting power fromt eh outlet make sure you have power going to the machine
May 16, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Model R134a Refrigerator...Freezer works fine but no cooling in the refrigerator... What can I do if anything besides replace it?
Two things, One, the coil in the freezer could be Iced up, deforst the freezer.
Two, the circulatng fan is not running.
Sep 01, 2009 | Frigidaire Refrigerators
Frigidaire Model FEF365BGWE Oven not working, Error F3 on display
I found this:
"F3 - Oven temperature sensor circuit fault
The manufacturer has assigned this error or fault code to indicate that the oven temperature sensor has failed. Test the sensor with an Ohm meter for the proper level of electrical resistance. The sensor is not repairable, if it is defective it will need to be replaced."
If it was me, I'd find the oven temp sensor (long thin metal thing like this: http://partsdr.com/part/5304497424-oven-sensor-kit/ this may not be the exact replacement part) and examine it. Unplug it and plug it back in. Maybe it's just lost proper contact. If not, don't waste a lot of time one it...just get a new one. They don't cost much.
Apr 22, 2017 | Frigidaire PLEF398AC Electric Kitchen...
Dishwashers Logo
75 people viewed this question
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
