SOURCE: error code
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If you’re any good with computers, it’s a
standard hard disk - you can take it out very easily, stick it in a PC, and
format it. That should work OK. If you’re not any good with computers, maybe
you know somebody who is? Apart from that, to take it out, you just open the
case, disconnect a ribbon cable, a power cable (plugs for both just pull out)
and 4 screws, then out it comes.
Alternatively, you could get a very big
hammer and smash it to pieces, which is what I feel like doing with mine...
Roger
SOURCE: cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
SOURCE: Need Replacement Cables for Javelin Surveillance Camera
I was the last employee of Javelin Systems. I have very limited camera parts left. I just sold the last 6 pin connector to for the chromachip but have some other connectors left.
My contact information is at cctvman.com.
SOURCE: cctv wavy lines from camera
often problems with lines is either down to RF or if all the cameras are powered of the same psu that it could be that your psu is underated and the cameras are pulling to many amps most moden cameras rum anything from 200mas upto 1.5amps with infra red so if you only have a 500ma psu its going give up slowely
SOURCE: Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
