I have pulled the plastic panel across the back where the recess is and now i dont know what to do as everything seems rigidly mounted. Can someone describe exactly how to open up the fridge enough to reach the defrost element? Thanks
Make sure it is totally defrosted before attempting to remove it they can be a little awkward, usually there is some kind of retainer to keep the collection grill in place if not then you need to been it outwards to reach the element,before you do that disconnect the element and test it with a multimeter to make sure it needs replacing
SOURCE: THE TOP PART (FRIDGE) IS NOT COOLING
We had the same problem. The duct between the freezer unit and fridge is probably iced over - a design problem apparently. Allowing to completely defrost will solve.
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Testimonial: "which temerature censor ( there are three )"
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
SOURCE: Fridge compartment not cooling. Freezer
Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
SOURCE: Fisher & Paykel Fridge E522B
Probably needs new fan. Most likely broken wire. Others have soldered if break easy to get to.
heatman101
