Heating & Cooling Logo
S
Steve Klein Posted on Dec 13, 2018
Honeywell thermostat t8112d1005.I changed the batteries. The temperature keeps blinking. How do I fix It
5 Related Answers
A
Anonymous
  • Posted on May 20, 2008
SOURCE: How do I change the
Try adjusting the heat range up. Set it a 77 then try the cool.
I believe the Honeywells have a max range between cool and heat.
also sometimes there is a lock out code on them you'll need the book.
Good luck
Anonymous
  • 116 Answers
  • Posted on May 15, 2009
SOURCE: how to remove thermostat cover to replace
the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
dkeven
Don Numinen
  • 69 Answers
  • Posted on Jul 10, 2009
SOURCE: How do I
the unit has a split line where to top meets the base plate pull on the bottom side with your fingernails at the split line and it will pop free it will take some force batteries are accessable after that, just line up and push to reinstall
Ryan Ross
  • 19 Answers
  • Posted on Sep 20, 2010
SOURCE: How can I get a user manual for the Honeywell
http://www.air-n-water.com/manuals/t8112dmanual.pdf
Anonymous
  • 43501 Answers
  • Posted on Jan 30, 2011
SOURCE: how do you unlock a
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Need manual for thermostat model T8112D1005(1)
http://www.manualslib.com/products/Honeywell-T8112c-10483.html
1helpful
Honeywell manuals
I usually google the model number when I'm on a service call and need the installation instructions for programming some thermostats. I googled "Honeywell T8112D" and the pdf file was the first link, that's the one you want. Hope this helps!
How do you unlock a honeywell thermostat t8112d1005
heatman101
7helpful
2answers
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
1helpful
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Thermostat does not follow the setting
If the thermostat is a digital /programmable you may want to recheck program to see if it has changed or been changed. If thermostat is not digital then it is prbably warn out and need replaced.
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
