Question about Electrical Supplies
My 7500 onan generator will not crank over - Electrical Supplies
Posted by Jerry simon on
Carl Rock
  • Electrical S... Master
  • 2,437 Answers
Check battery voltage. Should be 12.3 - 12.6VDC.
Lower reading indicates insufficient charge.
If reading ok, check for spent fuses. Clean battery terminals.
Try a jumper pack and see if it starts.
Posted on Oct 30, 2019
sherlywang
    Master:
  • 425 Answers
Contact your supplier to help you maintenance.
Because only they are clear about your product.
But if you consider to buy diesel generator set to supply power, maybe you can conatct [email protected] or visit www.dieselgeneratortech.com. They have focused on diesel generator set for more than 43 years.
5 Related Answers
Anonymous
  • 837 Answers
SOURCE: Looking for an ONAN Emerald I GenSet generator manual
I have an account in the Buffalo NY area .. they can help you with this .. call 716-668-2666 after 9:00am EST tomorrow (sat)
Posted on Apr 03, 2009
Anonymous
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Posted on Apr 30, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: Onan generator making grinding noise while cranking
If it walks like a duck and quaxks like a duck?
If it grinds like a starter ?
Your alternator would hsve to be in absolutely unaerviceable condition to match a noise a starter makes.
Posted on Jun 14, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: Onan 4kw Emerald I generator will not crank
The gen. is not the problem, the engine start circuit is not functioning. You need to look at the starter solenoid and starter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 05, 2009
Why onan 7500 HDKAJ rv generator will not turn over.
If the start battery is definitely good then why is the starter not getting energized? Ignition switch? Low oil switch, on/off switch? Safety switch?
There is something that you are overlooking. Bet that if you take a wire and hook up one end to the + terminal on battery and the other end to the plus wire on the starter it will crank!!!!!!!!
Sep 21, 2015 | Electrical Supplies
How to correct over crank fault??
Over crank is failure to start, check fuel and ignition, why it isnt starting
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
WHAT IS ERROR/FAULT CODE 37 ON A ONAN 5500 MARQUE GOLD GENERATOR ?
Code 37 is a bad set configuration, that means engine cranking speed and generator output aren't happy with each other..
Sep 30, 2014 | Onan Marquis Gold RV Generator 5500 Gas
Onan genarator will not crank
If it wont crank, check to see if the solenoid on the starter pulls in, the starter and solenoid are one unit, it sounds like an internal starter contact, if you have 12V going to it. Assuming the battery is good. When you press and hold the stop button does the fuel pump pump prime? if so control board has power
Mar 24, 2014 | Onan Generator, 6500W, LP Vapor
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
Oct 22, 2009 | Watts Onan Portable Generator - 5000 ,...
Jun 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
138 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
