Question about Sunbeam Food Mixers
My sunbeam 2371 just stopped working while making cookies. Turned off to let cool off,, light comes on but still not working, Is there a reset button.
Posted by SHIRLEY CANTELUPE on
warpdrive_al
    Habit-Forming:
    New Friend:
  • 6 Answers
You may need a diagram for this. There may be a diode in line with current. If so, it functions as a circuit breaker to keep from damaging the motor. If no current goes thru diode but is at the "front", then replace diode. Also something made the diode malfunction, so you need to investigate. My money is on the motor. It is probably starting to ground out.
Posted on Jan 25, 2019
1 Related Answer
NOT ME
  • 2841 Answers
SOURCE: My Sunbeam Heritage MixMaster mixer just stopped
If it is plugged into a circuit protected by a GFCI breaker, which it should be if it is a kitchen circuit, reset the breaker. If you know for sure there is power at the receptacle you have it plugged into, then the power cord is bad or you have an internal mixer problem. You will have to pay someone to repair it or take the mixer apart yourself and find out what is wrong. Before paying someone be sure and get an estimate as to the cost of the repair. In some cases you are better off buying an new mixer as the repair costs will exceed to price of a new one.
Posted on Dec 18, 2009
Speeds do not work in graduations in Sunbeam Model 2371 12 speed mixer
Problem with speed control device. Check switch for continuity with various speed settings.
Dec 24, 2016 | Sunbeam Food Mixers
Sunbeam beaters hitting each other
Check with Sunbeam. The beaters may have to be replaced.
Dec 11, 2013 | Cuisinart Food Mixers
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
When making cresceent cooky batter what mixers do I use to make the dough?
If you're making cookie batter, you use the whisk type mixer(s). If it's a bread dough, you use the solid flat type mixer(s).
Jan 07, 2011 | Sunbeam Heritage 2346 Stand Mixer
I have a mix master 2366 275 watt my daughter was making cookies and it just stopped working.It is only a couple years old
it may be that the Solid State Speed Control has gone bad did any smoke or bad odors come out of the mixers but if you have any warranty period left then they will gladly fix it
Jan 02, 2011 | Sunbeam 275 Watts 2367 MixMaster Series...
I have the Sunbeam portable mixer 2486. I was making Parker house rolls with the dough hooks. After blending the dough, the mixer just stopped. The motor will no longer be turned on or off. I want to...
Hi Janis.
You have likely burnt the motor. That is the most common fault when the mixer is used for a prolonged time on a compact dough.
The best thing to do is ringing Sunbeam at the number listed on the owners manual, and checking what conditions for repair are offered.
If you have misplaced the manual, then track the number using Sunbeam website: Sunbeam.
Regards.
Mar 02, 2010 | Sunbeam 2485 MixMaster Series Hand Mixer
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Our late model epicurean mixer strains and makes clicking noises when blending heavy loads/molasses cookies, etc. repair worthy or junk it?
Well, Matter of opinion on the junk it part. Sounds like it is grossly underrated and would only be good for light blending.How did it work when new? What was its cost new? If you use it alot and love to make things where you need it, I personally wouldn't compromize on the tools of your labor. I think you can tell I'm a mechanic.Don't show your husband this. Sounds like you deserve a Sunbeam Mixmaster. Now that can double as a mulcher out in the garden. Kidding. Weigh the cost and use. Good luck on you decision. Let me know, I'm just curious.
Oct 27, 2009 | Food Mixers
My sunbeam mixmasters turntable is not turning
Hi Jill. Your mixer's gears are made of plastic and can't really handle heavy loads such as cookie and bread doughs. Contact Sunbeam Corp. to locate a parts place near you. You'll need to replace at least the large gear that turns the turntable base, possibly the worm gear that turns the large gear too. Grease these gears when you re-install the parts. You'll have to cut a couple of cable ties to get the machine apart enough to do the work. If this solution has assisted you, please rate it. Good luck! ricardok45.
Mar 09, 2009 | Sunbeam Food Mixers
Food Mixers Logo
397 people viewed this question
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
efs_perpends
efs_perpends
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
