Pitco Frialator SG14 Deep Fryer Logo
Question about Pitco Frialator SG14 Deep Fryer
I have a Pitco SG14-JS double fryer, the one fryer needs a new tank, is it possible to seperate the 2 fryers so I can just use the one fryer
4 Related Answers
Anonymous
  • 11 Answers
SOURCE: fryer is taking to long to filter oil
If your oil is bubbling while returning, I would suggest checking for a air loss. be sure that your stainer cap is tight and make sure your o- ring in the pick-up tube is there and in good condition. Slow return and no bubbles, be sure the filter paper is installed correctly and clean. If your paper has been subjected to moisture or being installed without drying a wet screen, then the fibers will fuse together and restict the flow rate.
Posted on Feb 02, 2009
kebah
Angel Joseph Jr.
  • 685 Answers
SOURCE: hi I just baught a used pitco frialator sg18 Js
You can download programming guide at pitco web on www.middleby.com
Posted on May 17, 2011
kebah
Angel Joseph Jr.
  • 685 Answers
SOURCE: is it possible to convert an electric pitco deep
It is not because the fry tank construction is not the same.
Posted on May 28, 2011
kebah
Angel Joseph Jr.
  • 685 Answers
SOURCE: pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Posted on Sep 13, 2011
Pitco fryer sg14
Sounds like propane. Please is heavier than air. Try opening air shutters on burners.
Our church has a Pitco Frialator Model #14UFMS 110,000 BTU. Do you have a manual?
Hi there.
You can download Pitco Fryer Owner's Manual at
http://www.pitco.com
Regards.
2helpful
What are most common problems found with pitco frialator fryers?
Some of the most common problems with Pitco fryers is failed Hi-Limit thermostats, carbon build up on burner tubes, and dirty or clogged burners. This hi-limit thermostat is mounted inside the fry tank on one of the burners. Often the cappillary tubes are damaged or broken during cleaning causing the limit to fail. The hi-limit is the most common part I replace on Pitco fryers. The other common items are self explanitory. Keep the fryer clean in all areas, including burners and tubes. You will see the repair man less often.
How do you clean the Pitco Friatlator deep fryer?
Visit pitco web at www.middleby.com, there are manuals which will help you in cleaning fryers.
I need to adjust the timer on the right side fryer basket
Hi there.
If your fryer is PITCO, you can download programming manual at http://www.pitco.com
Regards.
Pitco fryer
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at http://www.middleby.com
2helpful
2answers
My pitco gas frialator oil leak in tank .how can
You need to identify where the leak is coming.
If the leak is on the fry tank, best way to address it is to replace the oil tank.
Check the serial number of the unit with leak on fry tank, verify if it is still under warranty at PITCO web on http://www.middleby.com.
5helpful
3answers
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
1helpful
Wiring diagrammed of Pitco model 7-2wkss
Sorry to break this to you but all pitco fryer model numbers start with an S, please make sure what manufacture this fryer is made by.
Thank You
15helpful
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
