H there try this... Deactivate the oven with the house fuse or the safety switch in the fuse box and activate it again. If the above advice does not resolve the problem, we recommend requesting a visit by a repair technician or check out your other option with an expert https://www.6ya.com/mr.mike Good luck and thank you
Mr.Mike
You will need to have an electrician connect the oven to your power system in your home, unless you are expert at doing this yourself. ZOP37902XK Ovens Zanussi Products Cooking
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Was the oven tripping the the fuse before the element was replaced,also did you take the oven out to do element because the element can be done with cooker in place it may be that you pulled out the connections block at rear of unit and it is touching body.If tripping before replacement the fault could be any where on the oven.You will have to check it through.
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
