SOURCE: remote
http://www.replacementremotes.com/store/productdetailp.cfm?productid=1563
There ya go... just type in kenwood cd-204 remote in google.
SOURCE: about the laser eye
you can go to wal-mart or any electronic store and get a laser eye cleaner for DVD this will also work on the ps1 & ps2 but not the ps3 - I recommend the Philips system, for under $15 you get the DVD laser eye cleaner and a disk cleaner with a micro fiber cloth it's a great deal just DO NOT use it in a laptop, laptop's take a different type but the disk cleaner is universal
SOURCE: JVC tha75 r where is laser eye bit so i can clean it?
claire_unbre:
When you say laser eye, are you referring to the laser used to read your cd's & dvd's? if so, you can find dvd cleaners at most retail stores. the kit will contain a disc that looks like a dvd with built-in brush & cleaning solution. follow the instructions on the cleaning kit & you should be OK. reply if you need additional assistance.
peace-out
SOURCE: cd player in my ford 6006e will not play.just shows error code 4.
phillips dvd lense cleaner £5.95 asda
Possible that the main loading or the front loading mechanism is struck or jammed. You will need a visual indication of the mechanism to confirm.If so remove the mechanism and reset, If not the loading driver IC is faulty or the motor has failed.
However if the CD is not detected the optical is not working,as there is no laser scanning and the possibility that the laser head can be defective.
It is ideal to clean manually the laser head eye using a cotton bud with gentle pressure on the lens eye.
