Question about Cobra 148 GTL 120-Channels Base CB Radio
The wires inside my turner dm7800 base mic
The wires inside my turner dm7800 base mic has come away from the circuit board they are red white and blackdont know where they go can you help please
Posted by alex thomson on
3 Related Answers
anymhz
AnyMHz.com
  • 500 Answers
SOURCE: how do you wire atrb-x2 echo board in a cobra 29
don't worry about wire colors. pin 1 is ground. some mic's need two wires for ground depending on the PTT switch used. pin 2 audio. pin 3 TX pin 4 RX.. thats all there is too it. once you know the pins all radios are easy. galaxy/connex/genlee same pin outs except pin4 isnt' needed for RX but can be used for 9v dc to power micropohnes.
Posted on Dec 04, 2009
Anonymous
  • 12 Answers
SOURCE: I have a cobra 148gtl with 5 pin side plug for
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
Posted on Jan 25, 2010
maxmrossi
maxmrossi
SOURCE: Need Cobra 148GTL with Cobra HG M75 pin-out color code
The above wiring combination does not work
Posted on Sep 16, 2012
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Based on the Delta Force Schematic and the Turner +2 diagram 1=White 2=Red 3=Black 4=No connection (Unless you install 2 scan buttons in the Turner +2) 5= Shield Switch the internal switch in the bottom of the microphone for Electronic Switching (Not Relay). :-)
Aug 24, 2014 | Radio Communications
NEED TO WIRE LESON MICROPHONE TO MAGNUM 257
Notice the black mic plug has the numbers it is solder by numbers. Used rosin core silver solder radio shack sells it.
Mic Wiring
Stock
1-Shield (ground)
2-Yellow (audio)
3-Red (transmit)
4-White (receive)
Astatic
1-Shield & Blue
2-White
3-Red
4-Black
Yellow NC
Turner Roadking 56
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC
Sadelta the is a BASE mic
1-Shield
2-White
3-Brown
4-Green
Oct 02, 2011 | Magnum 257 CB Radio
Mike wire color coat.
1 is shield (and may also need blue for astatic mic or red for turner mic)
2 is audio (white on astatic and turner mics)
3 is Transmit (Red on astatic mic or blue on turner mic)
4 is receive (Black on both astatic and turner mics)
If your mic isn't an astatic or turner, email me with what mic that you have and I'll try to help. [email protected]
Mar 18, 2010 | Radio Communications
Wiring of turner dm 7800 base mike [ old
hello i have now got the problem solved thanks to your team very fast response thank you 54 alex
Jul 30, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Wireing turner plus 3 to president washington that is four pin
Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
Jul 23, 2009 | Magnum DeltaForce CB Radio
Mic wireing
For a Turner +3 it is 1/shield 2/white 3/black 4/red.For an Astatic 4 wire it's as follows 1/shield 2/white 3/red 4/black ; for a 6 wire it is 1/shield&blue 2/white 3/red 4/black - yellow no connection . Good luck....Dan
May 01, 2009 | Magnum DeltaForce CB Radio
Explaihow to wire a turner +3 mic to a president washington base
Here you go 1/shield 2/white 3/black 4/red . Good luck......Dan
Apr 28, 2009 | Magnum DeltaForce CB Radio
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
I have a turner plus 3 mic with 4 wires red,black, ground and white. i need to wire it to a 5 pin uniden washington radio, looking for a wiring pattern with pin number to wire color
Here are 2 way's
1- white
2- shield
3- black
4- red
5- blue
yellow is not used.
if this dose not work try moving the red wire to pin 5 and the blue wire
to pin 4
Mar 04, 2009 | Uniden GRANTLT 40-Channels Base CB Radio
Palomar 150watt bi-linear amplifier for c.b. radio-SHORTED
OPEN IT UP THE SHORT MAY BE WERE THE 2 POWER WIRES COME TOGETHER AS THEY ENTER THE RADIO THIS HAPPENS ALOT OR DESOLDER ONE OF THE WIRES OFF THE CIRCUIT BOARD AND CHECK FOR A SHORT ON THE WIRES AGAIN THIS WILL TELL YOU ALOT IF IT IS THE WIRES OR IF IT IS ON THE CIRCUIT BOARD GOOD LUCK
Jan 06, 2009 | Radio Communications
Cobra 148 GTL 120-Channels Base CB Radio Logo
91 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
