Question about Siemens SpeedStream 2624 Router (936-2624-001 kit)
Pvc selection keeps changing to dial up mode
My siemens gigaset 587 kepps automaticly changing the pvc selection to ippeoa(dial up mode) . i have a broadband connection so it should stay on pppoa can i stop it from switching to dial up mode
Posted by devonbrivett on
Anonymous
    Scholar:
  • 148 Answers
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Posted on Aug 12, 2009
I need a user manual, in English, for a Siemens AL 170 Duo phone.
Click HERE and select Siemens AL 180 from the drop down box.
AL 180 has few more functions.
The setup instruction should be the same as AL 170.
Jul 28, 2011 | Lands Phones
HELLO EVRY BODY, We have a cordless phone gigaset 4015 with gigaset confort handset 4000 the only problem is when we receive a call , we can hear only the first ring and the handset still blinking...
First of all you have to change the Dialing mode, DTMF or Pulse, according PABX type, ask to technicians!
Second step is to set up the Flash Time from 80 to 800 ms, again in dependency of your PABX Operating Instructions. Cheers and good Luck.
Oct 09, 2017 | Siemens Gigaset 4015 Cordless Phone
How do you reset the base and handset of a Siemens 4215 to "0000" ?
My Siemens Gigaset AS15 Cordless Phone is constantly calling the same number, no matter which number I dial! What shuld I do?
Thank you.
Jan 31, 2010 | Siemens Gigaset 4215 Cordless Phone
Change recorded message
Please follow the steps:
1. Press MENU
2. To select "ANSWERING SYSTEM MENU?", press SELECT
3. Scroll to "GREETINGS?" and press SELECT
4. Scroll to type of desired message and press SELECT
5. Scroll to "RECORD GREETING?", and press SELECT
6. Record a message or greeting through the base speakerphone or base station handset. 7. Press SELECT to play back greeting/ message.
NOTE: To avoid background noise, record message through the corded handset.
Sep 12, 2009 | Siemens Gigaset 8825 Cordless Phone
Retrieving message
First set up a pin # or use the default which is 0000.
Then from a remote location:
  • Dial the Number
  • Press * Twice before the greeting is completed
  • Enter the Pin
  • Select * to hear all messages or Mailbox number which you are calling to check
  • Use the menu below:
5 - Play New Messages
6 - Record Message
7 - Play All Messages
8 - Play Greeting
9 - Record Greeting
0 - Turn System Off
# - Access help
Sep 17, 2008 | Siemens Gigaset 8825 Cordless Phone
Siemens se 587 router
HI,
You can try manuall setup of da router.
The Default gateway for Siemens Gigaset SE587 is 192.168.1.1. Open Internet Explorer and put the def gateway in the browser.
The default username and password for siemns router is admin.
Click on Setup Tab than Basic Setup on left hand side. Update the details as folloing-
Use – Tiscali data PPPoA Interface
PVC Selection – Tiscali data PPPoA
Authentication – Auto
User Name - Tiscali u/n
Password - Tiscali password
PPPoA Connection Mode- Always On
NAT - ON
And click on save settings. To confirm if the customer is connected, check the status of Online light – which should be green
. Alternatively click on status (On top) to check internet status to confirm connection.
Setting Up Wireless connection – Click on da wireless tab on the top.
Ensure that the Auto channel is disabled and the wireless channel is 11, wireless n/w is Enabled and mode is Mixed.
To secure the wireless connection – Click on Wireless Security option on left hand side
If you want the Security mode as WPA than select the wireless security mode, as WPA and enter WPA Shared key which would be on the base of the router. Again click on save settings.
Try connecting to the wireless network again and I m sure it should work..... lemme know if it does.
Cheers
SHADAB
Mar 26, 2008 | Siemens SpeedStream 2624 Router...
Siemens SpeedStream 2624 Router (936-2624-001 kit) Logo
304 people viewed this question
Top Siemens Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Terry
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
