Question about Karcher Garden
Karcher wv50 doesn't stay on - Karcher Garden
Posted by Robert Taylor on
2 Related Answers
Timllfixit
  • 2210 Answers
SOURCE: My Karcher WV50 stops working after 3
Sounds like its jammed or very stiff in the motor and the overheat/overcurrent trip is operating. An electrical appliance repairer could look at it for you but bear in mind his costs versus a new item.
Posted on Sep 20, 2014
JohnPaul Robertson
  • 342 Answers
SOURCE: i have a karcher wv50 when i press the start button it just flashes
Roy it sounds like this is a problem. If it's flashing the pump may have stuck and you need to invest in a new machine. If its under any insurance make a claim.
Posted on Nov 02, 2014
Why won't it switch off?
Because the switch is broken and stuck in the "on" position. Until you fix it all you can do is plug it in and out for operation. If you are handy you can take the switch out, make the repair of the broken part, and reuse.
They wanted 35 dollars for the switch on my Karcher power washer. Yeah, right!
Aug 04, 2015 | Karcher WV50 Window Vacuum
I have a karcher wv50 when i press the start button it just flashes
Nov 02, 2014 | Karcher Pump Kaercher KH 5050/L
Is the battery sealed onto the circuit board in my karcher window vacuum
No it is not it is a tight fit on clips on battery,.thanks be very carful wires very hard to get off thanks A Rudd
Sep 30, 2014 | Karcher WV50 Window Vacuum
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
Aug 02, 2014 | Karcher WV50 Window Vacuum
Why is my karcher wv50 blowing out water through its air vents
Have you over filled it and tipped the karcher to one side that sometimes makes warter blow out the vents give it a good shake on its side then try again.
Jul 31, 2014 | Karcher WV50 Window Vacuum
Where's the serial number on the karcher WV window vacuum
Hi. I've just bought the karcher window vac wv50 & am having the same problem finding the serial No. I presume you want to register your product for the guarantee to be valid. I went online Karcher.co.uk & registered mine. You will note that when doing so it does not ask for a serial number but a model No. This is found on the side of box you got the item in (mine is just above the barcode) & it reads something like; 1.633-113.0. Hope you still have the box!
Jul 23, 2014 | Karcher WV50 Window Vacuum
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
Jun 23, 2014 | Karcher WV50 Window Vacuum
Garden Logo
43 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
