Thats a simple one to replace. Unplug unit. Take a putty knife and release clips that secure console to top. They are located on each front corner of console. Raise lid. Unplug harness from switch. Take ground screw out that is part of switch assembly. Release plastic tab that holds switch in place and remove switch. Install and snap into place new switch with lid open. Put ground screw back in place and plug harness back into place. Lower lid and then raise and listen for clicking noise. Put console back in place. That’s it.
SOURCE: Kenmore 80 series lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up.
Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap.
Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
SOURCE: replace lid switch assembly kaws850
The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
SOURCE: Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
SOURCE: Replace "lid switch" on kenmore washer 110-20702-991
Go to www.appliancehelponline.com/servicemanual.html this will walk you thru the lid switch replacement.
Switch will be located under console on left side while standing in front of washer. Console hinges back after clips are released.
