Question about RCA Audio Players & Recorders
I need to get my rca 5 disc changer open - RCA Audio Players & Recorders
6ya staff
SOURCE:
Anonymous
SOURCE: 5 DVD disc changer doesn't open
are you using discs with labels that you out on your self? I had a similar problem before and my label peeled off in the player causing it to get stuck., you might just have to take it apart, and get the label out.
Posted on Nov 06, 2007
Anonymous
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
Anonymous
SOURCE: my rca 5 disk vertically
Try this... unplug the unit and turn it upside down.  Have a small screwdriver ready.  No plug the unit in and try to turn the wheel in the large slot clockwize.  When you see the spring clip try to grab the white plastic stop and move it clockwize.  This should eventually open the door.  It did for me.
Posted on Dec 29, 2008
Anonymous
SOURCE: 2005 Lincoln Aviator 5 disc
TRY REMOVING THE RADIO FUSE & WAIT A WHILE. IT SHOULD RESET WHEN PLUGGING THE FUSE BACK IN.
Posted on Mar 19, 2009
Kevin Braid
  • 382 Answers
SOURCE: jvc xl-f254 cd changer for home. 5 disc
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Posted on Jan 29, 2010
RCA 5 disc changer tray want open
It will be due to the end of the player
Aug 20, 2016 | RCA RP8078 5-Disc CD Changer
Won't play any disc on any of the 5 slots boom box also has casette player that records
Laser is either dirty, so a lense cleaning disc required. Or the cd transport is kaput. Uneconomical to repair if this is the case
Apr 11, 2014 | RCA RP8085 5-Disc CD Changer
My RCA RTD 206 5 disc changer wont play DVD's. It stays on Disc 3 or just says close. I called the # in the manual foe help, but its no longer in service.
If it plays the same disc without issues, you have a mechanical(or the electronics powering the motors and such) problem. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
Rca 5 disc changer
What model RCA changer?
Jul 19, 2013 | Audio Players & Recorders
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
I a home rca 5 disc cd changer it will read my cds
Hello
Hello
You have an RCA 5 disc CD changer and it reads CDS. Then what is the fault?
Jan 17, 2012 | RCA Audio Players & Recorders
I have got a rca 5 disc changer rp 8055c it want play my cd
RCA 5 DISK CD PLAYER AND RADIO CANT HERE MUSIC LIGHTS COME ON CD PLAYS BUT NO SOUND.
HELP
Aug 16, 2009 | RCA RP8078 5-Disc CD Changer
79 people viewed this question
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
