Question about Frigidaire Dishwashers
SOURCE: Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Posted on Aug 24, 2007
SOURCE: frigidaire dishwasher wont run
Thanks for your help. My dishwasher did the same thing today -- green lock light came on and I couldn't get it to run. I checked the bottom of the tank and I had some glass lodged in the drain. Cleaned it out and held the button down for 5 seconds and now it runs again.
Posted on Feb 28, 2009
SOURCE: Hi, my Frigidaire dishwasher doesn't seem to clean
Factory Defect, where I was given full refund plus re-installation costs from Lowes...
Posted on Oct 17, 2009
SOURCE: Frigidaire Dishwasher FDB956RBC0
I successfully replaced the broken handle for my ELECTROLUX 24" Built-In DISHWASHER Model FDB956RB.
Try to check to make sure you reassembled all the parts and wire connectors properly.
Other than the broken handle, did you have other problems prior to replacing the handle/latch?
Posted on Nov 28, 2009
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
Hey Louise Mekic, thank you for your inquiry!
I see that you are having a issue with your silverware not drying properly in your Frigidaire dishwasher. It could be that your silverware is too close together and that is called nesting, once items are too close water can accumulate on them. I would try to set them further apart to see if that would correct the issue with your silverware not drying. Hope this is helpful. -Matt
Aug 18, 2014 | Frigidaire Dishwashers
May 25, 2014 | Frigidaire Dishwashers
May 08, 2012 | Frigidaire Dishwashers
Jul 17, 2010 | Frigidaire Dishwashers
Apr 07, 2009 | Electrolux Frigidaire Professional Series...
Feb 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Jun 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Mar 20, 2008 | Dishwashers
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Nov 16, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Jan 04, 2021 | Frigidaire Dishwashers
169 people viewed this question
