Question about GPS
Toyota 2L VVT cylinder head bolts torque specs
VI AHTCW12
Posted by Marks on
5 Related Answers
emissionwiz
Marvin
  • 85239 Answers
SOURCE: 2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
Posted on Sep 08, 2008
Anonymous
SOURCE: Hi I need torque specs for b5 dohc(cylinder head job)
the pdf manual says it is 10 - 13 ft lbs  from my research it is 75 ft lbs
I hope I am right cus I just set my head at that :( before i got the pdf file!
havent started it yet though
Posted on Mar 13, 2009
Roger Foster
  • 701 Answers
SOURCE: torque specs for toyota tercel
Hello vienotkelly: The correct Main bolt torque is 42 foot pounds. The connecting rods torque to 29 foot pounds. The torque sequence for the head bolts and the correct way to tighten the bolts are attached to this reply. Thak You for using6bd0ae1.jpg FixYa. Roger
Posted on Apr 15, 2009
Anonymous
  • 1392 Answers
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Posted on Aug 16, 2009
inspectmycar
Chris Biddle
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
My 1983 mark vi wont stay running
  1. 1983 LINCOLN MARK VI Idle Air Control (IAC) Valve
    www.rockauto.com/catalog/x,carcode,1188323,parttype,6072
    1983 LINCOLN MARK VI Idle Air Control (IAC) Valve - RockAuto.Com, 1983 LINCOLN MARK VI Idle Air Control (IAC) ValveĀ® ... No Parts for This Category ...
Apr 21, 2012 | 1983 Lincoln Mark VI
Firing order for 1983 lincoln mark vI with 5.0 electronic fuel injection
  1. Firing order for 1983 lincoln mark vI with 5.0 electronic fuel ...
    www.fixya.com/.../t12248217-firing_order_1983_lincoln_mark_vi_5_0
    Mar 31, 2012 - The firing order for that vehicle is: 1-5-4-2-6-3-7-8 ... the clusters gauge has a resistor behind it which is at fault.
Mar 31, 2012 | 1983 Lincoln Mark VI
1983 lincoln mark vi how to set the time
see internet.
1983 LINCOLN MARK VI Timing Set - RockAuto
www.rockauto.com/catalog/x,carcode,1188323,parttype,5756
1983 LINCOLN MARK VI 5.0L 302 cubic inch V8 : Engine : Timing Set, Price, Add ...Timing Set - 3 Pc.
Feb 22, 2012 | 1983 Lincoln Mark VI
My nuvi wont stop asking me to push the dot
Try performing a soft reset on the unit.
Resetting Your nüvi
If your unit stops responding, turn off the unit, and then turn it back on. If this does not help, perform a reset using the reset button on the bottom of the unit.
Caution: Do not reset your nüvi with a ballpoint pen or other sharp object, which can damage your unit.
1. Disconnect the nüvi from external power.
2. Press the Reset button on the bottom of the nüvi.
3. Connect the nüvi to a power source.
A hard reset can also be done but will erase all the user data.
This is done by with the unit off and pressing and holding the bottom right hand corner of the screen while turning the unit on.
Also try running the Garmin WebUpdater and reload the latest update again.
Download and Install WebUpdater
Sep 26, 2011 | Garmin nuvi 205W GPS Receiver
My garmin 200 gps is not coming on?
Resetting Your nüvi
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
Sep 15, 2011 | Garmin nuvi 200W GPS Receiver
Screen does nothing just says garmin
Resetting Your nüvi
Aug 24, 2011 | Garmin nuvi 205W GPS Receiver
Garmin turns off when Garmin screen comes on
Resetting Your nüvi
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
Problems with FIC VI 39L Motherboard No sound
Here is FIC's Site to download drivers + Manual etc:
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=38
Jan 10, 2010 | FIC VI 39L Motherboard
How do I reset garmin 205 w
Resetting Your nüvi 205W. PLEASE READ ALL BEFORE TRYING.
If your nüvi stops responding, turn the nüvi off, and then turn it back on.
If this does not help, reset your nüvi.
Press and hold the RESET button on the bottom of the nüvi for several seconds.
Clearing User Data CAUTION:
This deletes all user-entered information.
1. Hold your finger on the lower-right corner of the nüvi screen while turning on the nüvi.
2. Keep your finger pressed until the pop-up window appears.
3. Touch Yes to clear all user data.
All original settings are restored.
Any items that you have saved are erased.
Let me know if it solved it.thxx
Jan 12, 2009 | Garmin nuvi 205W GPS Receiver
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
GPS Logo
204 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
