Question about Amana Heating & Cooling
Hi I'm Steve... Amana SSE80 Furnace Model GUIC070CA40 MFG # P1229003F Furnace works but air handler blower stops after 5 1/2 minutes, burner continues till high-T limiter triggered (See details)
Problem: All steps for furnace work fine except 5 1/2 minutes (almost like clockwork) after air handler starts up fine, runs fine, runs smooth and quiet it stops and the furnace inductor blower/heat continue until it trips the high temp limit and shuts all down. After verifying two or three times after cools down I started killing heater before the furnace high heat limiter trips for subsequent tests after a new filter was installed and I verified no obstructions and a free spinning blower. When we first ran the furnace we did get a rubber/electric burning smell not like the gas/dust burn we are accustomed to at the start of seasonal use and the smell comes back some just before shut down. The back of the motor is warm and the body is quite hot to the touch. If I had to guess I'd say bearings or other going in motor and thermal protection for motor kicking in. Your thoughts? Other: Last summer the A/C condenser had issues while I was out of the country. I had a tech come by and verified a bad controller. I ordered a refurbished controller and walked son through how to change over skype. That fixed that problem but may have issues on the furnace side though I can't imagine what that might be based on the consistent failure sequence and timing each time. Your thoughts? Recap of what works: -- Calls for heat fine, furnace inductor blower engages as it should, -- Ignitor fires and burns blue and clean non stop until high heat limit reached, -- Air handler blower starts smooth and runs smooth but dies after +/- 5.5 minutes. -- Replaced air filter, old one not that dirty. Blower free spins by hand, no rub, no noise I have two larger Amana units as well and had to replace one. I scavenged the blower unit with mounted controller and the controller should still be good. The blower motor looks like the same frame type but is a 3/4HP where the SSE 80 is a 1/2HP.
Posted by Steve Carroll on
Andy
    Loyalty:
    Visited the website for 30 consecutive days.
  • 572 Answers
Motor might be bad and shutting down on thermal protection. Is this a direct drive or belt driven ? .if belt driven try adjusting the belt tension or just replaced the motor
Posted on Dec 11, 2018
5 Related Answers
fscanlan
  • 21 Answers
SOURCE: fi have a older furnace that operates like this. main burners will come on then the blower turns on and furnace continues to heat untill it shuts down on the high limit. there is no blockage on the co
Maybe there is a blockage in the air conditioning coil above the furnace? This happens when people have pets, or dont use filters. Single phase 120-240 volt motors won't run backwards if you reverse the wiring that's dc or three phase, you have to check the rotation of the wheel, the right rotation is usually marked on the blower case. Some motors will allow you to change the rotation but you have to check the wiring diagram. Also use new capacitors when they go bad the motor can run backward. God luck
Posted on Dec 21, 2011
Hollenback
  • 520 Answers
SOURCE: Furnace shuts down before heat
has any one checked your thermostat. as soon as the furnace shuts down then turn up the stat and see if it starts right up. i would think the stat function should have been checked also.
Posted on Feb 12, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Main blower fan is not starting on my York Diamond
Check to see if the blower motor is actually getting power to it...You will have to check for power on the heating speed terminal... and the neutral wires....you should have 120v across those two wires....
If you have power then the motor is bad...if no power then the heating relay went bad on the circuit board and you will have to replace the circuit board...
That is a common problem as those relays are often to light and wear out...
Just realize that without an electrical meter to trace things through you are really just grabbing at possibilities and not really able to correctly diagnose your problem...
heatman101
Posted on Dec 08, 2010
cookhvacr
  • 5 Answers
SOURCE: Ruud Silhouette II Gas Furnace, purges, lights
Flame sensor needs to be cleaned. turn off the furnace power switch or breaker. pull the flame sensor located in the burner runner section of the furnace. It will be easy to locate because it has 1 wire running to it. pull the screw being very careful not to harm anything else. get the sensor out. inspect it for cleanliness. clean the sensor with light grade sand paper gently. re-install the sensor plug the wire back on. restart your furnace and this should fix the problem.
CookHVACR
Posted on Nov 19, 2010
Testimonial: "thanks cookhvacr, took 15 minutes and it seems to be back to normal operation."
1STHVACMAN
  • 69 Answers
SOURCE: Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Posted on Aug 03, 2009
Carrier electric furnace (air handler) stopped running
The 5 amp fuse may be bad, they go quite often, and they are exactly the same as the car ones. Check the fuse with a meter. If its OK turn the unit on and check for voltage going to the blower fan. You should get a reading between at least one pair of wires. The unit should have a schematic on it somewhere, check it to see which wire pairs are used for the variable speeds of the fan.
Nov 08, 2014 | Heating & Cooling
Carrier electric furnace/air handler stopped running
Check fuses first! If yours is the model with a fuse box you will see a flap that pulls down to reveal a block of fuses, the blade fuse you described is part of it too! Are all fuses ok?
Carrier air handler/furnace won't turn on
from what your saying the motor is hot to touch if that is the case the motor is bad need to be replaced.
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
COMPRESSOR Amana / RCE24C2A Ser #036142440
mfg date are coded into the ser.# useualy fist 4 digits are yr and month of MFG. 0306 would be 2003 june ect. if in doubt call amanna dealer and ask them. Steve
Jul 12, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
43 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
WatsHVAC
Level 1 Expert
Brad Scarpetta
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
