Question about Samsung Audio Players & Recorders
How do I connect bluetooth headphones to my Samsung smart tv model un55f6300
Posted by Mike Guilford on
2 Related Answers
Danny Kuhlmann
  • 1443 Answers
SOURCE: need instruction manual for samsung tv #un55f6300
here is your manual:
Samsung UN55F6300 Manuals
Posted on Dec 09, 2015
emissionwiz
Marvin
  • 85239 Answers
SOURCE: I purchased a Samsung UE40KU6100XXU curved 4k UHF TV is there a way how I can use my Bluetooth headphones with this model made in Slovakia?
Unless in the manual it specifically says the TV has Bluetooth then the answer is no.
Posted on Jan 27, 2017
How do I hook up a wireless headphone set to my Samsung 50 Smart TV?
Depends on your headphone. Just follow instructions on headphone manual and tv. Personaly i doubt you can pair bluetooth phones to tv directly, never seen b4. BUT, you can buy from ebay bluetooth TO audio adapter. There is ebay item number 222294284409.
Long story short, its rechargeable and works fantastic. Dont forget to follow pairing instructions.
Feb 18, 2018 | Samsung Audio Players & Recorders
Can i use bluetooth headphones on the smart tv
if your tv is smart, it is probably Bluetooth compatible. you may have to go into settings of the tv to turn the Bluetooth on, while your headphones are in Bluetooth mode and on.
Dec 13, 2017 | The Audio Players & Recorders
How do you pull up bluetooth on a samsung tv ?
Hi recently I wanted to pair my bluetooth headphones with samsung smart tv and I followed this video.
Maybe it helps you as well.
Goal is to go to the hidden service menu and activate it there.
The key combination is :
Turn off the TV.
  1. Info
  2. Menu
  3. Mute
  4. Turn on the TV.
Oct 30, 2016 | Samsung Computers & Internet
How to connect to a Samsung tv
If you have Samsung wireless and need to pair them, then select sound, addition setting arrow down to Bluetooth ( may not be visible until you arrow down). Follow those instructions.
below this you will find how I set up old headphones.
I have a Samsung SU 4K, I also have an old wireless head phones. I did not want to buy expensive Bluetooth.
how did I make these work. First I purchased a digital optical convertor for $20. Since my headphones are 2 channel, I connected the base (red/white) to the convertor. Then I had to access Samsung menu audio. The Samsung TV has the manual built into TV terrible. Since I did not want the TV speakers off I had to find how to enable the output to headphones base. Select sound from menu , then additional settings , set audio format to PCM, also HDMI to PCM.
Jan 10, 2016 | Samsung Radio Communications
How do I stop the flickering of my Samsung HD Smart TV screen?
http://www.shopjimmy.com/samsung-bn44-00612b-power-supply-unit.htm
Sep 16, 2015 | Samsung UN55F6300
Will tv volume and headphone work at the same time? someone can hear headphones at the same time the tv
If I understand your question correctly, you want to use headphone AND be able to play through the speakers at the same time?
Not usually. Most headphone circuits disconnect output to the speakers when you plug in headphones.
Nov 22, 2014 | Vizio XVT553SV 55 in. LCD TV
Please help me - unresponsive remote?
that being a universal remote as i was reading means they have to be paired .
turn tv off .
go into program mode , hit sumpin on remote till it turns on your tv . hit save .
its something like that always but for your remote i don't find the exact instructions.
maybe if you give us the remote model number. we can find it.
Jul 25, 2014 | Samsung UN55F6300 55-Inch 1080p 120Hz Slim...
667 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
