I have connected my cable box to the appropriate HDMI slot on my receiver and using the HDMI arc output, from the receiver to the tv's HDMI arc slot. When trying setup, the tv can't see the receiver. When I connect the cable box to the tv directly, into the HDMI 1 slot, it plays through perfectly although sound obviously only plays from the tv speakers. I called the support units of both TCL and Marantz. TCL made a valiant effort with all kinds of suggestions to the settings in their tv app. Marantz couldn't even be civil and only blamed the tv company. Anyone have any suggestions? Thanks Gerry
Hello Gerry, what type of HDMI cable do you use for the interconnection, a 1.4 or a 2.0?
With the 2.0 you ensure that both devices are within the communication range and therefore should be recognized
Tell me the type of cable you use
I wait your answer
I sent you the link so you can download the user manual
Greetings Franco Dosil
Hola Gerry, que tipo de cable HDMI utilizas para la interconexion, un 1.4 o un 2.0?
Con el 2.0 te aseguras de que ambos aparatos esten dentro del rango de comunicacion y por lo tanto deberian reconocerse
Comentame el tipo de cable que utilizas
Espero tu respuesta
Te envio el link para que puedas descargar el manual de usuario
Saludos Franco Dosil
http://manuals.marantz.com/NR1605/NA/ES/download.php?filename=/NR1605/NA/ES/pdf/NR1605_NA_ES.pdf
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
SOURCE: PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
SOURCE: XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
