Question about Palm Computers & Internet
Does anybody know where I can get software for an old PALM TX pda to download
  • Palm Master
  • 1,554 Answers
Hi,for computer or the pda?
Posted on Dec 10, 2018
Testimonial: "COMPUTER"
5 Suggested Answers
Anonymous
  • 14 Answers
SOURCE: Palm TX Handheld - Delete all records
Hi, the best option would be a hard reset. Before doing so, i would suggest doing one lase hotsync.
at the back of your pda, there is a reset button. press this. be prepared. as it is resetting, press and hold the power button as well as the up button. hold these for like 3 seconds then release. it will then ask you whether you wanted to reset it. press the up button once again and release. it will then reset the pda.
if these instructions are still difficult there are some at palm.com. best of luck.
Posted on Nov 30, 2007
Anonymous
  • 3 Answers
SOURCE: Software Help
xda devolpers (google it)
Posted on Jan 24, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Palm crashes with message "installer not compatible with my device" when I do magnifying glass icon search on Contacts
You should reinstall Palm OS and everything else after that.
Posted on Jun 21, 2008
Anonymous
SOURCE: I have a Palm TX.
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Posted on Jul 04, 2008
Anonymous
  • 100 Answers
SOURCE: When you do a hard reset:
A hard reset shouldn't effect the memory card if you want the memory card you can format it within the Operating System before or after the heard reset.
Posted on Aug 07, 2009
I have a new PDA a palm TX I purchased on ebay and
No, you can install it without removing the other, and yes you can install more programs.
Jan 10, 2010 | Palm TX Handheld
I have a new computer with windows 7 and I can't download my old palm installation cd
Check your PDA manufacturer's website if it is compatible with Windows 7. Even my recent Palm doesn't pass compatibility with Windows 7.
Nov 07, 2009 | Palm TX Handheld
Is there anyway to delete files from a Palm TX using the desktop?
Unless I'm not understanding your question, any entries that you delete from either the desktop or PDA will delete from the other device when you sync your PDA.
So, if you delete an item from your Palm desktop, the next time you sync your PDA to your desktop, the entry will be deleted from your PDA as well.
But, if you haven't backed up / synced your PDA to your desktop yet, install and run Hotsync Manager - do that first. And, perform that procedure often so that your info on your PDA will be safe on your desktop.
Hope this helps.
Sep 14, 2009 | Palm TX Handheld
I cant sync my pda pls help,
get the proper sync software. Check the usb cable and conect
Aug 15, 2009 | Palm TX Handheld
Bought TX but have no desktop software cd
HI,
Yes if you go to palm.com you will find a section for support. You can download everything you need there to get your PDA up and running. Once you have the software installed on your computer you will want to go in and enter all your information like names and addresses in your contact section. Once you have that all done you connect the PDA to the computer by using the usb cord and then hit HotSync. You can go back later and update any of your infomation right in the PDA itself. Best wishes. Let me know if you need any other help with this.
Aug 11, 2009 | Palm TX Handheld
Yes I would remove first
Aug 07, 2009 | Palm TX Handheld
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
Nov 19, 2007 | Palm TX Handheld
I'm lost already!
Sounds like your PDA is not communicating with the desktop software properly. (is it a refurbished unit?). I would recommend you un-install the desktop software completely, then do a hard reset on the unit. This should start you from scratch. Then, re-install the software and re-boot the TX and configure it, and try a brand new sync. If this doesn't help, you might have to return it. But first, try it with the desktop software on a DIFFERENT computer.
Good luck.
Nov 13, 2007 | Palm TX Handheld
Computers & Internet Logo
52 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
