Question about Ricoh Office Equipment & Supplies
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
Posted on Sep 19, 2009
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
Posted on Oct 25, 2010
SOURCE: how do I sloved error sc 542 for printer ricoh SP C312DN
Hi
The first thing I tend to do with any fault on a computer or related hardware, is to turn it off, unplug it from the power supply, turn off and unplug the rest of the system components. Wait for a few minutes, plug the equipment back in and turn all components on and then reboot the computer.
If you have already done all this without success, then I found this error code website, which gave the following:-
Description:- Print Ready Temperature Error
The heating roller temperature increase during a set time is not correct. The fusing temperature does not reach the print ready temperature within a set time after the fusing lamp has turned on.
Causes:- Defective thermistor. Incorrect power supply input at the main power socket. Defective fusing lamp.
This can be seen on this webpage:
Error Codes Ricoh Aficio SPC312DN Code 542
where you can change the model number to your particular machine by using the drop down menus along the top of the page:
You can also obtain a full service manual from this site.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 21, 2014
Oct 18, 2016 | Ricoh Office Equipment & Supplies
Jun 22, 2016 | Ricoh Aficio SP 3510DN
Jun 01, 2016 | Ricoh Aficio SP 3510DN
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Aug 27, 2014 | Ricoh Office Equipment & Supplies
Oct 24, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Jan 17, 2009 | Ricoh Office Equipment & Supplies
611 people viewed this question
