SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
SOURCE: Transfer belt error
Rather than turn printer off, unplug from power source, wait a few minutes and plug back in. It's worked twice for me so far...
SOURCE: Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
SOURCE: how do i clean a samsung clx 3175 color laser
You need to carefully vacuum out( do not blow in) all the loose toner. Then use cotton pads to clean up the residue that the vacuum does not get. Of course you have to take the drum out before you vacuum. You will see pickup rollers , clean them with a damp cloth with a dab of dish detergent. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
There is a optical lens on the top inside, use a clean cotton pad to go across it and clean it.
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
