Could it be a play n roll piano instead of a play n piano?
Manual for sale:
http://www.manualswarehouse.com/mant008.htm
There may be another manual on another web site.
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
..check it out....
http://www.blurtit.com/q717681.html
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
SOURCE: NEED MANUAL FOR SHARPER IMAGE JUMBO UNIVERSAL REMOTE 1613086
The manufacturer of that remote is Emerson. Here is the manual.
http://mscustomercare.com/forms/JumboRemoteEM_InstructionManual.pdf
SOURCE: need a user manual for Sharper Image MP3 player
This is the direct link to the pdf of the manual http://www.mscustomercare.com/forms/MP3_Camera_IM.pdf
:D
SOURCE: cannot play music on sharper image mp4
Hello
Ok, this means that the format in which you copied the files to the player is not supported. You need to convert the audio file to mp3 format before you transfer it to your player.
Hope this can steer you in the right direction.
Kind regards
Andrea
